Thread: Silicone sealant under lip of new shaft seal?
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Maybe I'm over thinking this...but from everything I've researched, this seems like a 50/50 opinion type of thing. What's you guys opinions? To me it seems like the sealant would be beneficial because it will prolong water from getting under the lip and behind the seal. Just need to be careful not to get any on the face of the seal.
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin S200 Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Silicone sealant under lip of new shaft seal?
    Where is the fifty fifty opinion coming from? What sources did you find that sealant is a good thing for a shaft seal. The lip seal on the shaft is designed to be able to move on the shaft. As soon as the seal moved, and it will, the sealant will no longer seal the lip seal.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Quote Originally Posted by CJadamec View Post
    Maybe I'm confused, but the shaft on my WhisperFlo motor slides right through the spring side of the seal that is seated in the middle of the seal plate. Are you telling me that both sides of the seal spin once the pump is turned on? When looking at my setup, it seems like the spring side lodges on the seal plate and wouldn't move, only the shaft would spin inside it. Again, not really sure how it works, I thought only the white ceramic side seated in the impeller spun.
    Read this thread Step 8 Pentair Whisperflow seal replacement How-to (w/ photos))
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Ceramic spins. Carbon doesn't spin. Carbon on the shaft is spring loaded and will move slightly as the shaft floats on its bearings and undergoes thermal expansion. It's not the seal moving so much as the shaft moving realative to the seal. At best silicone will do nothing at worst it will cause the seal to leak or fail premature.
    Chuck-
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Thanks for great explanation man! I'll leave it off!
    mas985's Avatar
    Pleasanton, CA
    11,984
    On some pumps, the ceramic is in the seal plate and does not move while the carbon spins.
    Mark
