Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: Clorox salt?
    Clorox salt?
    Picked up 2 bags today from walmart. Usually they carry the mortons. Anyone ever use the clorox salt??
    Thanks
    12' x 24' (21100 gal) Doughboy Desert Spring w/ Deep End, Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed,
    Hayward S210T Pro Series, Hayward H100ID1 H-Series , Hayward AQ-TROL-RJ AquaTrol Salt, TF-100
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    162
    Re: Clorox salt?
    I just bought a bunch the other day. I like the looks of it because it is very fine, but I haven't used it yet. It was also cheaper than the Morton's they also had in stock (same size bag). However, I was not a fan of their bags...I have salt in my car from where the bags were not well made.
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    Re: Clorox salt?
    Ill post back in a couple of days. Ill add one bag tonight to see if that brings me uo to range. I picked up ten bags in the store and they all leaked a little. I grabbed a few extra walmart bags to place them down in in the car. Haha
    Thanks
    Re: Clorox salt?
    I used some last week in anticipation of installing my IC40 over the weekend. I was curious to see how well my in-floor jets would distribute the salt as an experiment so I basically dumped 2 bags in the same general location and went inside for about 1/2 hour. From doing a little bit of research, and although perhaps not the best practice this did not seem like it would be a problem to do. When I came back out to take a look there was what I could best describe as a forming rust stain around the perimeter of the existing pile of salt and with a major streak headed towards the main drain.
    I quickly brushed out the remainder of the pile to stop that from happening further. Over the weekend I donned my scuba gear and spent some time on the bottom of the pool with a sock filled with crushed vitamin C tablets getting rid of the substantial stain.
    Needless to say, I did not, and won't be using that salt again. Perhaps it was something in my pool water that caused this reaction so I am not (exactly) blaming the Clorox Salt. Perhaps all salts would do the same under the same circumstances. I purchased the remaining salt needed from Leslie's and didn't have any problems, although I did not let it sit for any time before brushing this go around.
    Your mileage may vary, but I would recommend brushing it immediately after dumping it in the pool should you use it.
    11K In ground, plaster with spillover spa.
    Pentair IntelliFlo VS pump. Easytouch control with wired EasyTouch 8 remote and Screenlogic2 Interface.
    Pentair 250K Mastertemp Heater. All important TF100 test kit.
    SW Florida
    Re: Clorox salt?
    Instant Stain
    Second report of Clorox salt causing an iron stain.
    I think that I would avoid Clorox salt.
    Support the site
    Re: Clorox salt?
    Although very similar in shape, my stain wasn't nearly as dark as that one. That is downright scary. On the plus side the vitamin C in the sock did a miraculous job of cleaning it up, but I guess this means my water now has iron in it.
    SW Florida
    Jul 2014
    Hickory, NC
    162
    Re: Clorox salt?
    Quote Originally Posted by JamesW View Post
    Instant Stain
    ugh...Of course I just bought 8 bags so I'd be stocked up...
    ~ TF-100 test kit
    Re: Clorox salt?
    So far so good. Only one bag bit i did the usual of walking around the pool as i dumped it. Crossing my fingers
    Re: Clorox salt?
    I would return any unused bags and get different salt.
    Support the site
    Re: Clorox salt?
    I will be. Just making sure no stains from the first!
    Oct 2007
    Parkland, FL
    753
    Re: Clorox salt?
    I've used the Clorox stabilizer but not the salt. I usually get the other salt from Wal-Mart and no problems so far
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    JoyfulNoise's Avatar
    May 2015
    14,075
    Re: Clorox salt?
    I was not able to find any online product info from Clorox which tells me this is just a rebranded bag of salt from some random manufacturer. Anyone with a bag of this stuff should carefully read the product labelling to see if there is a country of origin on it or a different manufacturers name. Most of the Clorox Pool & Spa products are NOT manufactured by Clorox but by other companies and they just use the Clorox name on the packaging. In fact, I did a little careful digging and it turns out that Clorox simply has another shell company in place which acts as a partnership with a Canadian chemical manufacturer. So, in reality, when you're buying this stuff, you're paying for the name and that's about it.
    The fact that staining is randomly occurring leads me to agree with JamesW that this salt likely has yellow Prussiate of Soda (aka, sodium ferrocyanide, Na4Fe(CN)6) in it to act as an anti-caking agent. When the potassium ferrocyanide is added to pool water, the ferrocyanide anion (Fe(CN)64-, pale yellow) can be oxidized to the ferricyanide anion (Fe(CN)63-, dark red) and leave a stain. Over time, the ferricyanide will slowly breakdown to leave ferric iron (Fe3+) behind to form iron oxide/hydroxide stains.
    Matt
    Re: Clorox salt?
    Would this all depend on the existing water in the pool. Say it may act diffetent from one pool to the next? Still no problems here but will be returning the 2nd bag
    Re: Clorox salt?
    Probably depends on the specific batch of salt. I suspect that Clorox probably has the salt made by various suppliers.
    Probably need to contact Clorox to inquire.
    Support the site
    Re: Clorox salt?
    Not a baf idea. Wasnt sure if it was the water i get from the local water company vs another member getting it from another source. Just got home and still looks ok. Thank god
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    Re: Clorox salt?
    SAMs Club lists it as 99% pure., Assembled in USA, component from USA.
    7000k Viking fiberglass Bermuda, Sand filter w/glass, Pentair SuperfloVS, Pentair IC20 swg
    Raypak 106k, Dolphin s-200, Taylor k-2006c, Taylor k-1766, Speedstir, Little Giant cover pump.
    May 2015
    14,075
    Re: Clorox salt?
    Quote Originally Posted by Pyrodav View Post
    1% impurities in a 40lb bag dissolved in 10,000 gallons is roughly 4.8ppm. If that impurity is iron, you'll see it.
    Matt
    Re: Clorox salt?
    Ok. So my salinity is up to 3100 anf no signs of stains at all. All other levels are within the peramitiers. So for my pool the clorox salt seems fine but next time i buy i will get the mortons just in case.
    Aug 2008
    Pensacola, Fl
    63
    Re: Clorox salt?
    I got the rust stains with Clorox salt too. It was all that Walmart had at the time. Glad I only bought 2 bags.
    About 23,200 gal vinyl in ground, "stop sign" shaped 22x22, Polaris 3900 cleaner, Hayward Aqua Plus Pro Logic Controller, Hayward T-15 SWG cell, Hayward S244T sand filter.
  20. Back To Top    #20
    Re: Clorox salt?
    I really want to know why some get srains and some do not. Still wont be buying it again
