Results 1 to 10 of 10
Thread: My new custom Test Kit
    Jun 2015
    Georgetown
    23
    After a while, the TFP method is soooo good that you have to turn your attention to other pursuits. I stole this idea from someone else on this forum, but added my own touch as well. Since I now have test chemicals, a speedstir, digital pH meter and assorted vials,a large water sample bottle and extra skimmer socks., I wanted to get them all in one easy-to-carry case. Two days ago I received this Stanley Deep Organizer from Amazon http://a.co/3DGiBcS
    To make it a little more effective, I cut out 3x4 foam strips from some floor padding I had and drilled 1 inch holes in the top two layers. There is a third layer underneath it to provide a little more height so that the tops of the bottles just touch the lid when the lid is closed. I like to keep the bottles in order like they come in the K2006 case and this ensures they don't move around. I printed a color photo of the test kit instructions and laminated it as a sheet.
    A little shuffling of the boxes, plus drilling small weep holes in the bottom and the the cover to allow moisture to exit and voila. If anyone might appreciate the design, it would be the people here. Now I just need to hear about how I did something wrong and I will ruin my speedstir, pH meter or somehow mess up my test results
    I live in Central Texas and have a 12,000 gallon, in-ground, plaster pool built 2007. Jandy CL340 cartridge filter, Stealth 2.0 single-speed main pump. Polaris cleaner with booster. Attached heated spa with moss rock spillway to pool. K-2006 Test Kit
    Jun 2014
    17,323
    Re: My new custom Test Kit
    Welcome to the TFP "OCD" world of pool care. We've officially corrupted you.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,892
    Oh man that is so messed up! What you need to do is send it to me and I will "fix" it for you!!!! It will be all good when I lay my BLING hands on it. You may never see it again though as it will be living in my palace's cabinet!
    Talk to me more about how you did the foam. How tall is it? How did you drill the holes? I like the idea of the bottom part being foam still.
    You have SKILLS!!!
    Kim
    Jun 2016
    Poplar Bluff, Missouri
    344
    You know just this morning I was looking at my test kit thinking, how can I make it better. Now that I've seen both of your kits, I have more of an idea now of what I'd like to do. Love both setups @PenskeFile and @Texas Splash
    AGP: 21' x 52" : 10,000 gallon
    100 lb. Sand Filter / 1 hp pump
    11-5 full sun
    Jun 2015
    Georgetown
    23
    Ha - thanks for the comment kimkats. The foam came from some flooring I had bought a while back at Harbor Freight for my home garage gym. It is much like this at Amazon, but I couldn't find the same at Harbor Freight's website today. The ones I have don't have that "faux metal" treatment like the Amazon link.
    I cut one 3x4 strip and made sure it was a good tight fit. Then I drilled three equally spaced holes down the center with a 1" drill bit. That became my template for the remaining foam inserts. I just cut a 3" wide strip from the foam with a razor knife and then used the template to cut across into 4"pieces. Once I had 15 of those, I set 5 aside to be the bottom layers. Then I put the template (with holes already drilled) on top of two blank pieces and drilled through those into a spare 2x4 at the bottom. I lightly clamped the foam to the board to keep it from moving around.
    After drilling the holes, I just inserted a solid piece into the bottom of each with two "holy" pieces on top of that. This keeps the drop bottles very secure and you can shake the whole container to your hearts content and they ain't moving.
    Happy crafting!
    Edit: actually I did find the HF version, I just didn't recognize it from the picture as 4 tiles. Here is a link You'll need to fin another use for about 85% of the material, but you sound like the type who can do that!
    Apr 2013
    Sacramento, CA
    2,769
    Someone make one of these things for KIM with pink flower stickers all over it otherwise her poor husband will hate us cause she will force him to make one!!!
    Jul 2012
    Tallahassee, FL
    33,892
    G??? My husband borrows MY drill as it is stronger than his! Now the razor knife is best left to him to use as I cannot cut a straight line.
    Kim (now where my glitter glue bottles?)
    Interesting. I went the other direction. I had a small box and I put in only what I need to test FC/CC and pH. I have another box that I rarely use to do all the other test. It seemed silly to carry around the big box just to test FC. And it keeps most of my bottle out of the sun and heat.
    I do my first aid kits that way too. A small box with the basic stuff and a big box that covers just about everything. I got tired of pulling out the big box just to grab a bandage.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
    Jun 2015
    Georgetown
    23
    In my case, the only thing that gets carried around is the water sample bottle. Everything else is kept in the utility room next to the sink.
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    'S , you can buy that foam flooring at any big box store like Lowes.
    7000k Viking fiberglass Bermuda, Sand filter w/glass, Pentair SuperfloVS, Pentair IC20 swg
    Raypak 106k, Dolphin s-200, Taylor k-2006c, Taylor k-1766, Speedstir, Little Giant cover pump.
