Results 1 to 7 of 7
Thread: Can i install a fountain on my return?
    steveb21's Avatar
    Mar 2017
    United Kingdom, England.
    198
    I have this type of return...
    Would something like this fit...
    http://www.ebay.co.uk/itm/bNew-Casca...oAAOSwuxFYuSZI
    Many thanks.
    Outdoor Inground Heated Concrete Tiled Pool - 25ft x 12ft and 3ft 4" to 6ft 6" deep - 45k Litre Water Capacity
    Valve - Hayward Vari-flo 711-13 ------ Pump - Sta-Rite 5P1R
    Filter - Hayward S244T -------- Test Kit - Taylor K2006C
    domct203's Avatar
    Jun 2015
    CT
    3,892
    Re: Can i install a fountain on my return?
    A little bit of Google searching & it looks like the fountain needs a 1-1/2" internal threaded wall fitting like the standard Hayward type fitting that uses adjustable directional eyeballs.
    http://www.poolmaster.com/product/re...fall-fountain/
    Your return (as in the picture) does not seem to have that internal thread.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Might be some kinda adapter you could rig up for it to fit. But I gotta tell ya'..........I got one of those and it hasn't seen daylight past the first couple of times I tried it. Both the spray and the led lights it produces are less than to be desired.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    A fountain will cause your pH to rise as well.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Apr 2010
    East Texas
    10,152
    I use a regular cheapie screw in flower fountain to help lower water temps over night in July and August though.
    steveb21's Avatar
    Mar 2017
    198
    Hey all,
    Fountain would only be used for when kids are in pool.... just a gimmick really but will keep them amused.
    Will see if i can get some type of adapter.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,994
    Quote Originally Posted by woodyp View Post
    I use a fountain spray of sorts for the same purpose. I have a 1 1/2 " return that I screw into. But I'm the queen of tinkering with building my own out of PVC.
    I will say when I have the spray turned up high buy closing other return valves, the spray seems to deter horse flies that we have a problem with.
    I also don't have an issue with PH rise.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
