Thread: What kind of fitting is this?
    Sep 2016
    Katonah NY
    170
    Hi,
    My pool people installed a cleaner pump 2 years ago. This season (opened today) the cleaner seems to be leaking. What sort of fitting is this? How can I keep it water tight (can i use a hose clamp for now?
    Rich
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: What kind of fitting is this?
    Ok,
    This is the second one I've seen this week. Has to be a pool specific thing, because I've seen them no where else, and I've dealt with every conceivable flex tube fitting you can imagine. Except these, I guess.
    I would look for them where pool builders get supplies. In the meantime, a clamp might work and it's worth a try if the leak is around the ferrule of the fitting, give it a shot.
    Essential Links:
    That's the old style Polaris pump pressure fitting. R0621000 is the part number for the new style set of fittings.
    Support the site
    Sep 2016
    Katonah NY
    170
    Quote Originally Posted by JamesW View Post
    Thanks Guys! I ordered a replacement part though i did get it to stop leaking.
