Results 1 to 10 of 10
Thread: TF-100 pH reading off the scale?
    VinceL's Avatar
    Apr 2012
    Newton, NC
    207
    Question TF-100 pH reading off the scale?
    I have been trying to measure the pH in my pool using the TF-100 test kit. I've been using the TF-100 test kit for several years, and this is the first year I've had this problem. I fear the pH of my pool is totally out of whack.
    My first test showed that the color of the sample after 5 drops of the reagent was yellow. It looked more like the reading for the chlorine test. I verified I was using the correct reagent and tested again. I realized I was using reagent from about a year ago. So, I ordered a complete test kit refill. Now that I have fresh chemicals, I tried the test again. I'm still getting yellow. As a test, I took a sample from our kitchen faucet. It tested to 6.8 which seems reasonable. So, the test kit is working.
    But, I don't know how to interpret the yellow color when testing the pool water. Does it mean way too high, way too low or unable to determine?
    I have a Hayward pH sensor. Initially, it was saying the pH was high at about 8.3-8.4. After putting in some acid, the sensor said the pH was still very high. I brought sensor in, cleaned it, and reinstalled it. The reading came down to 7.4-7.5. But, when I took a sample (from the Sense and Dispense outlet), I got the same yellow reading for pH. The pH sensor is almost 5 years old. So, I've ordered a replacement.
    But, I am totally stumped on whether use acid to lower the pH or to raise pH with borax.
    Vince L
    16' x 37' fiberglass pool, 8' fiberglass spa, Hayward Swimclear C3030 filter, EcoStar VS pump, Pro Logic PL-PS-8, Goldline SWCG, Sense & Dispense pH control, Aqua Connect, PS-8 & Aqua Pod Remotes, Fiberstars LED's in pool & spa, AquaCal SQ175R heat pump, SR Smith Typhoon slide, Polaris 9300xi robotic cleaner, TF-100 Test Kit
    Mar 2014
    Gulf Breeze, Florida
    68
    Re: TF-100 pH reading off the scale?
    http://www.poolandspa.com/page784.htm
    If you get a yellow result, you have a low pH or acidic water. If the color is a deep purple, your pH is too high
    Chris Hawkins
    18,000 gallon vinyl Inground. Hayward Goldline Aquarite 40k SWG, Pentair Intelliflo VS pump.
    Polaris 3900 cleaner, Pentair Tagelus sand filter. AquaPro 1300 heat pump. TF-100
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Your pH is low. DO NOT add acid.
    You need to raise the pH now or as close to it as possible. Its gone on a while, but this is important. Do you have the products on hand to do it? Borax is good. Please let us know ASAP.
    We can addres the probe later, but do not let it control anything yet. Unplug the pump..whatever just take it out of the loop.
    Essential Links:
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,877
    What's the TA? I would imagine that the TA is also very low.
    -Brian-
    Pool/Spa, Pentair Equipment
    Aug 2016
    Las Vegas, NV
    21
    If I am not mistaken, very high chlorine level can bleach out results of PH test. May need to dilute test water and retest? Chlorine level high? Slamming?
    16,000 gallon in-ground, plaster
    Jandy 460 Cartridge filter
    Pool Cleaner
    Taylor K-2006
    Aug 2016
    Las Vegas, NV
    21
    Quote Originally Posted by troymeboy View Post
    So I retract my comment as 1) high chlorine over 10 ppm may gave a false purple endpoint and 2) you would add one drop of R-007 to neutralize high chlorine, not dilute.
    Phenol red turns yellow at PH 6.8
    Pool Cleaner
    Taylor K-2006
    VinceL's Avatar
    Apr 2012
    Newton, NC
    207
    Thanks for everyone's quick responses. I had a done a quick search and didn't find the info about what yellow means in the pH test. And, I've been having Internet problems since yesterday afternoon; the cable guy is supposed to be here at noon.
    Last night I added about 7 lbs. of Borax and after about an hour of running the pump got the pH up to between 6.8 and 7.0. I put another 1 lb. of Borax in and ran the pump for another hour. This morning the pH is 7.0. I have another 8 lbs. of Borax on-hand; so I can raise pH further if needed. I'm running the chlorine generator which should raise the pH some more.
    Doing some backward calculations using Pool Math, I figure the pH must have been down to around 6.1. The TA is 80 so I'm good there, and the FC is 6 with 0 CC.
    The Hayward pH probe is reporting a pH of 10.2 . It was stored in the house over the winter in its storage module with water in it. But, it is from 2012 so I guess it is past its useful life. I'll have a new one from PoolSupplyWorld next week.
    Vince L
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,301
    Aeration will help drive pH up without affecting anything else. Point the return eyeballs up so you see ripples on the surface. If yours is a spillover spa, run it full blast with the bubbles and everything.
    40,867
    You cannot neutralize the chlorine to make the pH test work. The act of attempting to neutralize the chlorine actually affect the pH test and makes it invalid.
    VinceL's Avatar
    Apr 2012
    Newton, NC
    207
    I'm running the spillover with the blower on. Lots of bubbles.
    Vince L
