Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: CH of 525
    Oct 2014
    San Antonio, TX
    450
    CH of 525
    I received new test reagents recently and my tests with new CH reagents gets 525 and my old reagents was 250. I simply moved on, but after reading another thread about high TA, I think I might test my tap water. I tested tap at pool startup 2 years ago and CH was 225. Last year when I was getting quotes for a home water softener, the tap was also CH = 225.
    My old reagents were 2 years old. 2 summers ago I was at 425 and last summer at 325 and now 250. The numbers seemed to have dropped relative to my loss in CYA and salt. Added 5lbs of stabilizer and 120 lbs of salt last year. 3lbs of stabilizer and 80 salt so far this year. We have had so much rain since 2 summers ago, I have added very little tap water t the pool.
    Reagents are stored in kitchen cupboard and never go outside.
    So other than testing the tap water with both sets of reagents, is there anything else I can do to make sure I do not have an issue with any of the 3 new reagents? I can manage my CSI with CH= 525 no problem, but if it is closer to 250, I need to manage it a little different. I got identical results for TA, CYA, and FC tests, so I have already discarded the old reagents. Here are my lasted results
    FC 5.5
    CC 0
    PH 7.8
    TA 80
    CYA 60
    CH 525
    Salt 3200
    Thanks in advance for any advice
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
    30,950
    Re: CH of 525
    I would disregard your old tests. So then, if you just pay attention to the new results, do you have any reason to believe your testing is bad? What is the CH of your pool refill water?
    Oct 2014
    San Antonio, TX
    450
    Re: CH of 525
    I plan on checking the CH in the tap water tonight. I received the new reagents about a month ago and had essentially moved on - kept the old reagents just in case I discussed on the forum. My testing has been very consistent the last 2 years - with the SpeedStir.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: CH of 525
    Good deal, and let us know. Thank you for starting a new thread for this as well. Looking forward to your results.
    Essential Links:
    Jun 2014
    17,333
    Re: CH of 525
    Me personally, I can be a pack-rat when it comes to pool supplies. I hate to waste money or throw things out. But when it comes to reagents, and the consequences they have on adjusting chemicals based off of old products test results, I'm compelled to toss the old stuff whenever I'm in doubt. You know the new stuff is good so I'd rely on that as well. I will also confirm ...... I've had to watch my CYA and CH much more the past season or two from all the rain. Keeps us on our toes.
    I also am thankful for my speedstir.
    Oct 2014
    San Antonio, TX
    450
    Re: CH of 525
    Ok. Old reagents on the tap water
    CH 175
    New reagents
    CH 325
    I swear the drops on the new R0012 look noticeably smaller. Should I try switching the tip on the old R0012 to the new bottle?
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,268
    Re: CH of 525
    Jagger, we haven't changed tip manufacturer of the TF-100 reagents, so the size should be the same. You can easily pop off the tip and switch it (make sure you rinse the tip with distilled water if you do so), but I don't think it will make a difference. One thing I started doing that really has helped me check my reagents and my testing method was using CH Standard. It is basically "pool water" developed with a set CH ppm. So, it is like having the answers to the test. I found out I had some ineffective R-0012 not long ago. Contact me at tftestkits@gmail.com if I can help in any way.
    Oct 2014
    San Antonio, TX
    450
    Re: CH of 525
    Rebecca, thanks for reaching out. I switched the tips and here are the various results on my fill water:
    old R-0012, old tip, and old reagents 10 and 11 - CH = 175
    new R-0012, new tip, and new reagents 10 and 11 - CH = 325
    I then switch the tip on the old R-0012 to the new R-0012
    new R-0012, old tip, and new reagents 10 and 11 - CH = 200
    For the testing on the fill water, I paid close attention to each drop from all 3 reagents and new R-0012, new tip did have smaller drops - I am blind and noticed a difference. I examined the tips and my first instinct was the new tip looks thinner than the old tip. However, when I had both off and started examining both closely, they looked very similar. So I asked my wife (who had zero clue on what I was doing), "do you see a difference in these tips?" And she immediately thought the new tip looked thinner.
    So the new results (using old R-0012 tip) of 200 is almost identical to what I tested last year and the year before (225). I guess what I do not know is what tip is actually accurate.
    What if I brought another tip into play? Does another one of the reagents have the same tip size?
    I know it is probably a little over the top, but out of habit, I do an old v. new check with everything - salt test strips, reagents, beer, margaritas, etc. The FC, TA, pH, and CYA were identical. New beer a little colder and new margarita a little saltier.
    Nov 2016
    Las Vegas NV
    35
    Re: CH of 525
    Quote Originally Posted by jagger2005 View Post
    .....What if I brought another tip into play? Does another one of the reagents have the same tip size?
    Maybe try this....approximately, 20 drops is equal to 1cc. So maybe use the graduated cylinder and drop in 100 drops of the reagent. That should be 5cc. Do it with each tip to see if there is a difference. If everything kept clean, the reagent should be able to be added back to its bottle.
    DanL, Las Vegas NV
    IG, 2009, 15kGal, 1.5kGal overflow spa, plaster, Pentair system, 420 cartridge filter, Intelliflow 4-160 main pump, Whisperflow feature pump, Poolvergneugen Pool vacuum, liquid chlorine and sometimes pucks, TF-100 test kit, city water autofill, gas heater, Aquatherm Ecosun solar 480sqft, EZ Touch panel with remote, system: Trouble Free Pool
    Dec 2015
    Doral, FL
    54
    Re: CH of 525
    I just got a set of CH test bottles from TFPTestKits. I noticed the same thing you did about the drops on the R-0012. It seemed as though the new tip drops seemed smaller and at first fell out of the bottle with less squeezing.!! I tested several times untill I got some consistency.
    Despite that, I did get a valid test using the Calcium Hardness Standard (200ppm). Maybe a little less volume helped drop size?
    I just cant believe how high my Calcium became by just adding water.
    Still cant figure how my salt climbed 1000 ppm. Could that have been baking soda or stabilizer additons? I'll post new question.
    17.5K gal,31'x15' IG plaster, Depth 4'-6', Built 2015, Pump: Jandy Pro Series Model FHPM 2.HP -2-Spd, 88gpm Turnover 3.3 Hrs; Heater: Jandy JE Heat Pump Model 2500T SWCG: Jandy AquaPure Ei Series Mod. Apure35 Max Output Hypochlorous Acid = 420 g of FC per day = 0.2666 ppm per hour; Filter: Jandy Pro Series Model CS 200; Cleaner: Jandy MX8, Test Kit: Taylor K-2006 Salt; Stenner 45M1; City Water:Doral, FL.
    Oct 2014
    San Antonio, TX
    450
    Re: CH of 525
    Not sure about rise in salt. I have added so little fill water since my first summer
    Oct 2014
    San Antonio, TX
    450
    Re: CH of 525
    Quote Originally Posted by panamax53 View Post
    Despite that, I did get a valid test using the Calcium Hardness Standard (200ppm). Maybe a little less volume helped drop size.
    Panama, I think you solved the problem. I tried DanL suggestion to measure out 100 drops using old and new tip on the old R-0012 reagent - bottle is about 1/4 full. Both measured just shy of 5 ml - identical. So I poured out just a tad of my new reagent and measured pool water. Got CH = 300 using new tip.
    Thanks for all the help, everyone.
    Mar 2016
    Granbury, Tx
    36
    Re: CH of 525
    I've had the same issue with my refill kit. My old test measured 350. My new one is about 550. I don't know what to go with either.
    19,600 Gallons, 34'x24' Cloud Shape, 3.5'-6'-4', 2 Skimmers, 4 returns, natural gray plaster, Oklahoma Flagstone, NPT Silverstone Ocean Blue waterline and maker tiles, Pentair IC40 SWG, Pentair FNS Plus 60 DE Filter, Pentair Intelliflo 2 VST, Pentair EasyTouch 4, Pentair Intellibrite 5g Color Led light, Polaris 280 cleaner, 1.5 ton moss rock waterfall, 785 sq. ft. exposed aggregate deck, and mosaic crab on bench, TF-100 Test Kit
    Oct 2014
    San Antonio, TX
    450
    Re: CH of 525
    Quote Originally Posted by Fish Outta Water View Post
    Once I had removed some of the drops from the bottle...about 100 drops. My testing came in line.
    Mar 2016
    Granbury, Tx
    36
    Re: CH of 525
    So basically you're saying the bottle is too full??
    Jun 2015
    Glendale, AZ
    158
    Re: CH of 525
    Buy the Taylor 'Standard' keeps your skills sharp in testing & accuracy.
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Oct 2014
    San Antonio, TX
    450
    CH of 525
    Quote Originally Posted by oldguy70 View Post
    What do you get with the "Standards?" A sample of pool water with a known CH?
    Jun 2015
    Glendale, AZ
    158
    Re: CH of 525
    Yes...Hardness is 200, and their TA is 100
    Oct 2014
    San Antonio, TX
    450
    Re: CH of 525
    Nice.
  20. Back To Top    #20
    30,950
    Re: CH of 525
    All tips in the TF-100 (R-0007,8,9,12) are identical.
    Off the subject a little, but informative, the drop size is NOT determined by the hole size. Held up side down, the drop is formed on the tip and the falls by gravity when the drop weighs too much for the "surface tension" to hold the drop any longer.
    If you hold the bottle sideways, you will not get the drop to form as symmetrical as it should and you will most likely negate the test.
