Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: Footprints in plaster!! Help!
    Sep 2016
    Healdsburg, CA
    22
    We chose a Wet Edge premier stone finish for our pool.
    You can see foot prints on the bottom, and marks that look like they were made by the polishing blade all along the bottom where the bottom meets the walls of pool. In addition there is a large platter size dark spot on one of the stairs. These marks were not there when the pool was first completed in Nov. The pool contractor oversaw the pool chemistry, etc. during the winter months. And we did not travel to the property until late Jan. That was when we noticed the marks. Pool contractor said it would go away once the water chemistry was set. The marks have not gone away. What happened?
    Inground 22x36, Wet Edge Primera Stone, Jandy CV 460 filter, Jandy ePump 2HP variable spd pump, Polaris 280 vac, DEL OZONE UV/Ozone, Rainbow 320 Inline chlorine feeder, Jandy propane fueled heater, Jandy AquaPure SWG, AquaLink Z4 controller, Jandy Pro LED lights, Coverstar pool cover
    edrn's Avatar
    Apr 2017
    Elk Grove
    46
    Re: Footprints in plaster!! Help!
    I'm sorry I can't chime in on what went wrong or if it will get better, but I hope it gets better and fixed!
    Proposed PB Pool June 2017; 21131, IG, Micro Radiance, 580 SQ Cartridge, Jandy Variable with additional Jandy 80GPM waterfeature pump, raised spa
    jjwalker's Avatar
    S. Louisiana
    198
    pics?
    18x36 vinyl / sport pool 5.5' deep / 1.5hp Tri-Star 2spd / Hayward c3030 325 sqft cartridge / ~15k gal / TF100
    Sep 2016
    Healdsburg, CA
    22
    Hi,
    I will post pictures this weekend!
    The applicator is proposing an acid wash treatment which, after doing some reading on this site, I realize is not the answer.
    onbalnce, the TFP expert, says the plaster should be polished
    Wish me luck as my husband & I enter into battle.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    570
    I would reach out to these people. They have a vested interest in proper installations.
    Wet Edge | About Us
    Post up some pics and or send them to the MFG
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Sep 2016
    Healdsburg, CA
    22
    Been in contact with Wet Edge. Yes, you would think they would have a vested interest. They sent me back to the applicator, saying they had not seen the pool and so could not comment on the solution the applicator was proposing. I will be able to take pictures this Friday and will post here as well as send to Wet Edge. I will continue to pressure them to help us solve this issue.
    Sep 2016
    Healdsburg, CA
    22
    Unhappy Re: Footprints in plaster!! Help!
    Hi All
    Well the applicator did an acid wash. They did not remove the water. The stain and foot prints are gone (see my pictures of these below). The plaster looks good.
    I don't know the exact procedure that was followed. (We do not live full time at the pool location) and even though we asked for an explanation they did not tell us.
    I do know after 2 weeks of working on it they put a 25-30#bag of soda ash in the pool and said there just a couple of spots left that they would spot treat. It's been a week since the soda ash. According to the pool contractor, who worked jointly with the applicator to fix the problem, the water chemistry is perfect. The water is clear. But there is a new problem...the plaster is slimy/slippery. We are so distressed!
    40,856
    It probably just feels that way because the plaster is now very smooth. Plaster feels that way to me since we have pebble
    Sep 2016
    Healdsburg, CA
    22
    There is actually a cloudy residue when the plaster is brushed.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,916
    That is normal. It is the plaster dust. You should brush, let it settle and vacuum it up as well are running the pump to help filter it out!
    Kim
    Sep 2016
    Healdsburg, CA
    22
    the plaster dust is slimy?
    40,856
    Feels that way, a little, but not really slimy
    Jul 2011
    Arizona & California
    833
    It is long past the "plaster dust" stage time. That ends about three weeks after newly plastering. Although since this pool underwent an (perhaps severe and major) acid bath, it could be producing plaster dust once again. Hard to say right now what is going on.
    Now six months later, the slimy feel and cloudiness could be being caused by aggressive water dissolving plaster material from the surface, or from very scaling water. The water test readings of pH, alkalinity, and calcium levels need to be known and considered in this situation.
    Sep 2016
    Healdsburg, CA
    22
    Just to be clear...pool was finished in November of 2016. Footprints & marks first noticed at the end of Jan.(see photos above). The marks got worse as time went by. The plaster applicator began a no drain acid wash 3 weeks ago, 5/1/2017. 1 week ago, Friday, 5/12, they added 25-30# bag of soda ash and had a pump in the pool moving the water around. Monday, 5/15 they turned on the pump, filter, etc. I don't know what they did as far as water chemistry. But I know they began balancing it this past Monday as well. I will try to get water test results ASAP! Thanks!
    Sep 2016
    Healdsburg, CA
    22
    Here are the results of the water test taken today.
    PH-78
    Alkalinity-100
    Calcium- 400
    Jul 2011
    833
    Who provided those test results? The plaster guy, someone independent, or yourself?
    Sep 2016
    Healdsburg, CA
    22
    an independent pool service guy.
    40,856
    Well, if you spend much time here you will see that we highly recommend that you invest in a proper test kit to maintain the pool yourself.
    Sep 2016
    Healdsburg, CA
    22
    Yes I understand. Unfortunately, we don't live full time at the pool location. At the moment we are trying to get through the immediate crisis. And all the comments from this forum have been very helpful.
    My test kit is on order and I will be doing as much as I can to maintain the pool!
    (All my pool stats are at the pool location. I will update next tine I'm there.)
    Thanks!
  20. Back To Top    #20
    Jul 2011
    833
    Based on those test results, I would suggest that no plaster material should be dissolving off the surface and causing a slimy feel. Have the plaster surface brushed vigorously and see if the condition forms again a day after brushing. If it does, there might be some unwanted deterioration going on.
    Double check the water parameters when you get a chance. In a few weeks time, you will have see how the plaster looks and feels, and then go from there.
