waterbear said:
I use supreme plus myself and you DO need to adjust the pH to target befoe you use it.
Also, dropping the pH form 8.0 to 7.5 will only drop the TA by about 8 ppm which is below the resolution of the TA test! That is why you did not see a change in TA. It did move but not enough to show up on the test.
OK, cool, thanks for that! After receiving the above advice, I decided to go by the textbook on this one. Here are my revised numbers as of this a.m.:
FC - 6.5 (within range, but a little higher than I would like)
CC - 0.0
PH - 7.5
TA - 70
CH - 290
CYA - 55
borates - 0
So now, I think I'm ready for the Supreme Plus...anything else I'm missing?
Dave
