Results 1 to 7 of 7
Thread: New Liner- what to look out for Massachusetts
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    We have our official second year with this pool.
    At closing last fall we noticed the liner is in need of stretching, but there are tiny rips in it so we figure might as well replace it.
    For those of you who have replaced the vinyl liner, is there anything that we should be aware of when calling for quotes?
    In ground Liner, MBP-125A Heat Pump by Aqua Heat , built 2003, 18x37 Grecian style, System 3 sta-rite filter. @22,000 gal, tftestkits TF-100 & 1766, USQ1102pump installed 6/2016, new liner installed 07/2017. Circupool SJ40 SWG (7/2018), Dolphin S300i 7/2016
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    Re: New Liner- what to look out for Massachusetts
    First and foremost, do you have documentation? Specifically the serial number and manufacturer of the liner?
    That will save a ton of money...they can cut you a new one with that info. If you cannot find it,
    you might find it behind the liner itself in the shallow end printed on.
    Otherwise they will have to come out and custom measure.
    Dolphin E10 Cleaning Robot.
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    I actually do have the paperwork that the previous​ owners left.
    The bummer is that they never sent in the warranty form, because apparently this has a 20 year pro rated. So we would only of had to pay 60%.
    However, the liner was installed in 2004, and it is already 100% faded, and has rips.
    Is that normal wear?
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    My understanding of pool liner warranties is that they only cover the welded seams...
    Chris | 16' x 34' 16,000 gallon | IG Vinyl | Pentair Tagelus sand filter | Jandy 2hp epump | AquaPro PRO1300 heat pump | Coverstar auto cover | Taylor K-2006 | built August, 2016.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    12 years isn't too bad for a liner life. The expectation these days is 10-15 at most.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    572
    I know the guys at Idea Pools in Southbridge MA. They do a lot of liner replacements and pool remodels. You can google them.
    Laura is the manager - tell her Blake sent you.. and see what they can do.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    Southbridge is quite a ways away from our house. Now, if our rental property had a pool, it is the next town over.
    Maybe I will still give them a ring a ding
