I need to replace the multi-port valve on my filter as it's cracked in a couple places and the previous owner apparently JB welded it a couple of times. I looked around it pretty thoroughly and only found a single number on it...but part of it is covered over by the afore mentioned JB weld.
How do I go about identifing it so I can order a replacement. Info I do have.
Make: Hayward
Flow info; 60GPM, 50PSI
Number partially covered over; SP-0711-A1[JB weld starts here]
Other then "Top" and "Bottom" and the information on the tag as to placement and effect of the handle I didn't see any other markings.
Any help appreciated.
~Matt
Make: Hayward
~Matt
