I know I am a pain with all the questions, but really I'm not getting a grip on the wording and meaning even after reading the whole PS. I don't understand when it says bring it up to shock level....how am I determining that level #?
So, you put 18.5 in the "now" box and put ??? in the target...skydiva44 said:I just tested the water again 30 minutes after adding bleach and my results were now 18.5, so I put that in the FC box and 80 as the target.
You know... with one of these little Easy Set pools, that is a really easy thing to do. Dump a thousand gallons, fill 'er back up, poof your CYA is down more where it ought to be and shocking to get rid of the algae is easier.skydiva44 said:it also told me to drain the pool down 20%.
skydiva44 said:Ok, I drained my pool down today, and as it got lower I could still see a little algae... filled it back up and these are my current #'s.
tc - 0
ph- 7.8
ta - 230
ch -120
cya - 60
FAS-DPD- 4.5
SWG 1
Normal 1-3
Shock 10Mustard algae 12
PC says add a 182 oz. jug of bleach
1 cup 7 oz Liquid Stabilizer
My questions are: Is Liquid Stabilizer the same as Phos-Free that I already have from the store?
Will I have to go to the store to see how much salt I need to add or can you tell me that from my tests?
