Results 1 to 8 of 8
Thread: PureLine Crystal Pure Salt System
    rosslamon's Avatar
    Mar 2016
    Northport, AL
    62
    Hey guys. I did a quick forum search and tried to find any details about anyone using this system. A few searches show that people say it feels and looks like a knockoff of a Hayward system. I'm just trying to figure out if it works and for how long. It comes with a 2 year warranty and the replacement cells form inyo (the only place that sells the system) are around 299 which isn't bad by comparison to some of the competitors. Any suggestions or guidance would be wonderful! Thanks!
    My pool: ~22.6K gallon. 16'x32' with 8 foot deep. 10 year old vinyl liner (prayers)
    Century A.O. Smith UST1202 56J C-Face 2 HP Single Speed Up Rated Pool Filter Motor, 19.6/10.4-9.8A 115/208-230V
    Hayward S244T ProSeries 24" In- Ground Sand Pool Filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: PureLine Crystal Pure Salt System
    Not a Salt pool guy here, so I cant say for sure. Others may be able, but from what I hear INYO Pools should give you good advice on this, and they are helpful on the phone.
    Essential Links:
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,248
    Ross,
    It does look like the Hayward... Just want to make sure that when you get any salt system, make sure you get one that is rated 2 x the size of your pool. The rating is made based upon running the cell 24/7 at 100%, something that you do not normally want to do.
    kenmacboston's Avatar
    Apr 2012
    Haverhill, MA
    33
    I've had a Hayward for 14 years, it finally died (board). I don't want to repair it. I am going to buy one of these and will let you know the results. I also picked up a generator from a company in Aussie, only $195 including shipping. Many more salt systems down under...
    Ken Macumber
    18,000 Gunite, salt system, 250K BTU Hayward Heater, Waterfall, Fiber Optic Perimeter Lighting.
    20 yrs pool veteran
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    245
    Anyone else heard anything about PureLine Crystal Pure Salt System?
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Oct 2015
    San Diego, Ca.
    801
    That's the one my neighbor got a short while back and could't be happier (and he's never happy......)
    ned8377, you'll need an Pentair IC 60 at least or 2 of the PureLine's hooked up. 45K gallons is a mighty big tub.
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Apr 2012
    Haverhill, MA
    33
    Yes I did. The one for $495. Hooked it up and it runs just like the Aquarite for half the price. The inline unit is the same size as the other, so swapping it out was easy. The only issue was that the flow sensor from the Aquarite did not work with the Pureline, so I had to install the new flow sensor that came with the Pureline. Make sure you have the correct voltage on the unit before you turn it on, it comes as 208V (mine is 208) so check your wiring on the aquarite before you turn on the pureline. Good luck.
    Ken Macumber
    20 yrs pool veteran
    Mar 2017
    Chicago/Northwest, IL
    62
    I installed the 60k gallon version about two weeks ago and so far, it's been great. I would say the manufacturing isn't quite top-notch - the cables were a little short for my pad, and the flow switch was a VERY tight fit on my 2" pluming, but it's working like a champ. Output is exactly as rated so far. I'm a little concerned that the 60k size is no longer on their site, and there's still no sign of replacement cells for that model, but I'll keep my fingers crossed.
    34k gallon, 3' - 8' deep, 45' x 25' plaster free-form, in-ground spa, Hayward MaxFlo VS, Sta-Rite System 3 S8M-150, Pureline PL7703 SWG, Dual 1HP Pentair spa booster pumps, Hayward H400FDN, Taylor K-2006 Test Kit, Dolphin Quantum
