Thread: Pool pump timer
    Sep 2016
    Laval, Quebec
    5
    Pool pump timer
    Had a new pool installed last October which I haven't used at all yet. It's by reading through this forum that I came to realize pumps use a great deal of electricity (duh). The PB installed a Hayward 1HP Super II pump (SP3007X10A). In hind sight I probably should have asked for a variable speed pump (unfortunately I found this forum after my contract was signed and not before). The pump runs on 220V and the electrician wired up the pump with a male plug (prongs are horizontal rather than vertical) that I plug into a corresponding socket(also installed by electrician) in my shed. (pump is also in shed)
    I figure I can install a timer to reduce my energy consumption. I found this on Amazon
    https://www.amazon.ca/Intermatic-HB1...termatic+timer
    Can I use this? Spec wise it seems to be able to handle the pump. I wanted to ask first before ordering it as it doesn't look like any other pool pump timer I have seen in stores before.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Pool pump timer
    It seems it should be able too, but I may get corrected.
    I mostly wanted to say Hi, and welcome to TFP!
    Essential Links:
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,310
    Re: Pool pump timer
    S,
    Most timers are built to be outside so they are in metal boxes to prevent water from getting inside.
    If your pump and power plug are inside a shed, I say give it a shot. It appears to be designed to handle the load.
    I would only be worried if it is in a location where it could get wet.
    rajung's Avatar
    Mar 2015
    Iowa
    257
    Re: Pool pump timer
    If it is to be located outside where it can get wet, I would get one of those grey outdoor plastic boxes in the elect. part of a building supply store.
    Come in different sizes.The front has a panel that has a rubber seal all around and 6 or so screws.Drill a hole at the bottom to run wire in/out of
    I even use one for my outdoor metal water resistant timer.those even get crappy with time.Plus they also work great for any drop cord being used as you can put the plug ins inside and they stay dry.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
