Thread: how install aqua genie
    Jun 2014
    new york
    26
    hello!!
    rebuilding pool and have problem with installing aqua genie skimmers..
    1. when sliding in wall skimmer goes 1/2" more inside than need (will not line up with liner) am i suppose to use some kind of spacer or they sent me kinda skimmer for walls with foam or something..
    2. there's 2 holes bigger 2" pvc plug(for what is that) and smaller 1-1/2" to pump. I want use 2" pipes so.. am i suppose to use adapter 2" to1-1/2 or..... can i plug small hose and connect bigger 2"(suppose to be pluged) with pump??
    3. there will be 2 skimmers maybe i should use 1-1/2" pipes instead 2" if skimmer has already that size hole
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: how install aqua genie
    What sort of pool is this exactly? Can you please add those details to your signature line? It will help get answers for you more quickly.
    Essential Links:
    Jun 2014
    new york
    26
    36x16 rectangle variable speed pump de 48square filter
