Results 1 to 7 of 7
Thread: Pad Replumb Suggestions Anyone?
    Apr 2017
    Berryville, VA
    8
    I'm looking to replace my single speed pump with a VS pump with a 2" port and want to upgrade my pipe to 2" at the pad. I have 1 main drain and 2 skimmers, and 4 returns. My issue is that the lines coming up from the ground are too close together to simply replace the tee's with 2" fittings because they are longer than the existing 1.5" fittings.
    One option would be to cut down the 2" fittings to shorten them to fit. Has anyone ever done this, and do you think it would be more prone to leaking? The other would be to add additional fittings to give me more room before collecting them together. Downside here is making the pad more busy and adding head with additional fittings.
    Anyone have any other ideas? Thanks!
    28,000 Gallon Vinyl; 1.5 HP Hayward SP; Sand Filter; Pentair Minimax Heater; Taylor K-2006
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,277
    Re: Pad Replumb Suggestions Anyone?
    Nova,
    Not sure why you want to re-plumb your pad?? It looks pretty good to me.
    Your VS pump will work just fine with the existing 1.5" plumbing, except of course where you have to adapt to the 2" pump fittings.
    I suggest you get rid of those Home Depot unions and get unions designed for pumps.. they look like this...
    They have an O-Ring on the threaded end that makes sure your pump fittings never leak.
    May 2009
    Youngsville NC
    395
    Unless you're going to dig up ALL the returns clear to the pool - I wouldn't touch a thing. In fact -I would be questioning why you need to change anything as long as it all works. As someone else stated - your VS pump can cope with the smaller plumbing just fine - It might even be able to accept the 1.5 inch plumbing directly - at most - only change what you need to to get the VS pump in, if necessary use some 1.5 to 2 inch adapters.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Apr 2017
    Berryville, VA
    8
    Quote Originally Posted by Jimrahbe View Post
    Nova,
    Thanks Jim, I'll put those unions on the list when I do the pump. I was thinking that going to 2" pipe as the 1.5's come together could increase my flow rate. If you don't think it makes sense, then I can stop obsessing about it!
    Apr 2017
    Berryville, VA
    8
    So it sounds like upgrading to 2" pipe from the collection/distribution points will not yield me much?
    I'm replacing the pump because when I tore it down to replace the seals over the winter, the seal plate was all chewed up and melted. I put the new seals in although the one didn't seat well, and gave it a shot, but it's still leaking. I don't know how old the pump or motor is, but rather than replace parts I prefer to go with a VS to save some energy, reduce noise, and have more control. Since PVC is cheap, I thought I would upgrade what I could if it would help. My logic tells me it would improve the flow so I could run the new pump at a lower RPM to get the same results I am currently getting. Is my logic flawed?
    Jul 2014
    Bedford, TX
    9,277
    N,
    Any increase in performance would be so little you would never be able to notice.
    But.. if it makes your feel better, go for it, it can't hurt anything..
    Apr 2017
    Berryville, VA
    8
    N,
    Thanks Jim. Can't help but be a little obsessive every spring!
