Results 1 to 14 of 14
Thread: Sacrificial Anode help
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    166
    I have a sacrificial anode that was installed when the pool was built in 2014. I've read varying opinions...some people think they are beneficial while others say not. I don't know anything about the type I have, how long they generally last, what kind of maintenance (if any) is needed, etc. When the time comes for replacement, is it a DIY or pro job?
    The pic isn't the greatest because the outside plastic(?) has yellowed due to sunlight. Thanks!
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    Mar 2013
    maryland
    139
    Re: Sacrificial Anode help
    I have a sacrificial anode in my swcg pool. Many companies sell them and some are in line and others can be clamped to existing piping, all attaced to your bonding wires. It is zinc and absolutesly becomes coated over the season. Per the manufactures instructions I remove it yearly and clean it to bare metal. I use an angle grinder but a file would do. When I loose too much zinc I will replace it, but that will take a good few years. In line or clamp on it is a realtivley simple DIY repair or replacement. I can't tell how to open yours from the photos, but it sure looks like it should be cleaned. I cant prove that it helps, but I would rather sacrifce the anode than have somthing else corrode. Hope this helps
    " A little knowledge is a dangerous thing"
    19,000 gallon sylvan pool, Easytouch 2 4p automation, Screenlogic interface, Intelliflo VF 3050 pump, Intellichem with Intellichlor 40 chlorinator/Muriatic acid, Raypac millivolt natural gas heater.Polaris pool cleaner with booster pump.Coverstar automatic cover hydraulic mechanism with PCS cover. Wet edge Luna quartz finish 2016. Northeast climate.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    ^Lifespan of the zinc is typically 3-5 years or 50% of diameter...filing off corrosion on mine is recommended every six months. Hope tat helps
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jul 2014
    Hickory, NC
    166
    Thank you both! I'm not sure what the original diameter was. I was able to take closer pictures of the bottom part and I think I can get into it, but I'd rather have some additional info before I try. Thanks again!
    ~ TF-100 test kit
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    Google "pooltool" - there are cleaning instructions either there or on YouTube
    Helpful Links:
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Quote Originally Posted by appstategrad View Post
    Sent from my XT1609 using Tapatalk
    Looks like an o-ring between the white pvc and the black cap. I'd try to unscrew it if it were mine...
    Chris | 16' x 34' 16,000 gallon | IG Vinyl | Pentair Tagelus sand filter | Jandy 2hp epump | AquaPro PRO1300 heat pump | Coverstar auto cover | Taylor K-2006 | built August, 2016.
    JoyfulNoise's Avatar
    May 2015
    14,093
    I am not a fan of these devices as I am of the (sound scientific) opinion that they are useless. At best you are simply corroding a chunk of zinc (forming yellow/white ZnO and Zn(OH)2 precipitates and coatings). Once the zinc bar becomes passivated, it no longer functions as an anode.
    What precisely do you believe these devices are protecting you from? And, which part of your pool do you think you are protecting with something like this?
    Matt
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Galvanic corrosion. The zinc is attacked before the steel walls... For me it came with the pool build, so I'll keep in in. I know that I have seen 1" thick anode rods come out of water heaters that are now pencil thin, I have seen the sacrificial blocks on boat outboards and lower units badly worn while the rest of the metal is in good shape, and I have seen what happens when a copper water pipe rests on a black-iron fire sprinkler line. I have to think there is something to it.
    May 2015
    14,093
    Quote Originally Posted by cjpwalker View Post
    Yep.
    Except for the fact that, in order for metals to be used in that way, they need to be properly matched to application. When one wants to create a sacrificial galvanic couple, the surface areas need to be matched, in other words, the areas of the cathode (your steel pool wall) and the anode (your chunk of zinc), need to be equivalent. Otherwise you will completely passivate the zinc metal with a zinc oxide/zinc hydroxide layer and it no longer conducts current. The anode becomes "polarized" (which is just a fancy way to say non-conducitve and charged like a capacitor) and it no longer protect anything. At that point, the only thing that keeps the anode going is by mechanically disturbing the surface and hoping that enough passivation flakes of so that it can conduct again and develop an cathodic current.
    In water heaters and boats, the placement of the anode is such that the water current is able to remove the passivation a bit and allow for it to act in a sacrificial manner. In most saline marine applications, one uses magnesium bars and blocks to protect outboards because magnesium is a better sacrificial material. In buried steel tanks, one usually bolts or welds many zinc bars onto the tank to help protect it; for critical applications, you actually use an impressed cathodic current protection (ICCP) system. ICCP systems are powered electrical devices that actually supply current to the thing they are protecting to keep oxidation from occurring.
    The chunk of zinc sitting in the bottom of a PVC well with pool water flowing above it is barely doing anything at all except slowly rotting away and probably protecting the first few feet of bonding wire that is buried underground. And that's the other thing, not only is a steel wall hundreds of times larger in surface area than the bar, the wire connecting it is usually very far away which limits it's performance as an anode. Sac anodes, like surge protectors, are point-of-use devices - they work most efficiently when they are bolted to the thing they are protecting.
    Unfortunately, this is just another one of those pieces of "pool equipment" that are added on to a pool because there some underlying "science" associated with them that is not at all matched to the actual application. Like UV disinfection lamps and ozone generators, these devices do something but the something they do is not necessarily significant. You could completely remove the device tomorrow and, over the years, not ever notice a difference.
    Matt
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Well that sucks... Lol
    Appreciate the info. Glad I didn't actually purchase the thing separately.
    So is there a way to effectively protect my pool?
    I've heard of running a current before - I manned a shovel one summer in college for the gas company, and they use that process where they are still using steel pipe.
    May 2015
    14,093
    For an inground pool with steel walls, there's not much you could do after the fact. You would ave to dig down or otherwise find a close attachment point to make a connection. The way to properly create a sacrificial ground anode is to bury several zinc bars attached at equal intervals around the pool. You then typically bury the anode in a cotton bag that is filled with a solid electrolyte. A standard formulation is to create a 2:1:1 mixture of bentonite clay:sodium sulfate:calcium sulfate you bag the anode with the clay inside the bag and the anode as well. The solid electrolyte is there to make sure that the zinc does not get polarized and allows the zinc to dissolve form the anode at a uniform rate. The sulfates create a slightly acidic environment and the sodium ions help to stabilize the zinc surface so that the zinc can dissolve as Zn2+ cations and not immediately turn into zinc oxide or zinc hydroxide. The bentonite clay provides a way of keeping the solids around the anode moist be retaining water. The bag should be buried in moist soil where it gets water form time to time, so near a drip system or some sprinkler that might hit it.
    Zn anode bars for these types of application are usually several feet long and a couple of inches wide. The surface area determines the maximum current density that the anode will experience which is directly relate to the reaction rate. The total mass of the anode will dictate how long it will last. There are lots of tables online which can give you a feel for the size and weight of anodes needed for an application.
    Bottom line is this - it A LOT of zinc....
    Matt
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Like you said - can't do much now... Was hoping you would tell me to connect a doorbell transformer to the bonding wire or something, lol...
    May 2015
    14,093
    If I could fix everything in life with some pieces of twine, chewed bubblegum and a bottle of aspirin, I'd be MacGyver and life's problems would be wrapped up in neat little 45min segments...sadly, I'm no MacGyver...
    I'm sure your pool will be fine...
    Matt
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    I believe MacGyver's powers were derived from a combination of mullet, windbreaker, and cheese. All three can still be had, but getting the proportions right is the challenge...
