Page 1 of 18 123411 ... LastLast
Results 1 to 20 of 345
Thread: Swamp Fever...First Time Pool Opening....SLAM Time
    Jun 2016
    Poplar Bluff, Missouri
    344
    I'm finally getting some free time where I can get my pool open and oh what a mess it is. The mesh cover was full of leaves under the surface of the water. Got out all I could but I had to take the cover off myself since I was home alone. I'm getting leaves off the bottom of the pool but I can only see down maybe 10" because it's so green. It's slimy along the wall and smells like a lake. Looks like I'm gonna have my work cut out for me.
    I need to hook up my plumbing this evening and continue to get leaves off the bottom.
    Here's some pictures of it.
    AGP: 21' x 52" : 10,000 gallon
    100 lb. Sand Filter / 1 hp pump
    11-5 full sun
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Re: Swamp Fever...First Time Pool Opening....SLAM Time
    Once you get your pump going. Post your numbers and we'll get that swamp clean again.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2016
    344
    Got all the plumbing hooked up and of course I have a few drips but I'm not going to worry to much about those right now. Skimmed a bunch of crud off the top, more leaves on the bottom and just fired up the pump. Looks like there is a bunch of what I assume is algae clumps all over the place.
    Here are my numbers:
    CYA = 0
    FC = 0
    CC = 0
    TC = 0
    TA = 100
    CH = 75
    PH = 7.2
    11-5 full sun
    Aug 2016
    Riverside, CA
    378
    How sunny is it right now?
    I'd bring that up to about 10ppm FC and then run it for a while, then bring up the CyA to 40 ppm, increasing FC along with it.
    Jun 2016
    344
    It's been sunny all day and 83 degrees out.
    I put enough bleach in to bring it up to 10ppm and I need to get more cya, only had enough to get up to about 20ppm.
    I've skimmed, raked, brushed the entire pool and I'm sure there are still some leaves at the bottom, just can't see them.
    Looks like rain the next 2 days and cloudy.
    11-5 full sun
    Jun 2016
    344
    0 was the chlorine reading this morning, guess all the organics in the pool burned through 2 gallons over night.
    Dumped 2 more gallons in this morning.
    11-5 full sun
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Don't forget that when you are SLaMMing you need to test and redose as often as possible. At least ever hour or so to start with. Once the chlorine starts to hold, then you can back off to ever few hours or so.
    Jun 2016
    344
    Gotcha, need to get more bleach. Just scooped out another 3 leaf rakes full of leaves, hopefully I have most of it out now. I did notice I can see a little farther down this morning...lol
    11-5 full sun
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    34,010
    I would not bring the CYA up any higher for right now. 20 CYA will help you not have to use as much chlorine.
    Make sure to take a pic a day so you can see your progress.
    Kim
    Jun 2016
    344
    @kimkats I'll leave the CYA as is for now then.
    FC = 3ppm
    CC = .5ppm
    TC = 3.5ppm
    Man I'm burning through the bleach, going to add more to get it back up to 10ppm. I can only check it at morning, lunch and evening....Is that ok?
    Took a couple of pics, I can see the color changing even after a few days.
    11-5 full sun
    Jul 2012
    Tallahassee, FL
    34,010
    If you can add at lunch you are going to be one ahead of what I say for working folks like us.
    1-morning after first cup of coffee
    2-lunch (lucky to have this option)
    3-when you get home
    4-after dinner
    5-right before bed
    This works for most for working days.
    Kim
    Jun 2016
    344
    So do I need to check it that often? Better place order for more reagents tomorrow.
    I hope I have finally gotten all the leaves out of the bottom, just when I think there can't be any more boom, more leaves....LOL
    Here's a picture from this evening before I skimmed, raked, brushed, skimmed and raked again.
    11-5 full sun
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    What I usually say is, test as often as you can. Every hour or so to start. Then as the chlorine starts hold, you stretch it to every few hours. The more you test and redose, the faster it will go.
    Jun 2016
    344
    @pabeader I was just wondering because I won't be able to test that often other than what I mentioned above.
    11-5 full sun
    Jul 2012
    Tallahassee, FL
    34,010
    You test as often as you can........life comes first! It will take a little longer but even testing 3 times is better than none.
    Kim
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    No problem. Just a rule of thumb. You do what you can, and we will be here with encouragement as needed.
    Jun 2016
    344
    Checked it before bed and FC was 9.5ppm, added enough to get it up to 13ppm and this morning when I checked it was at 10ppm. It sure looks a lot better than it did but I still have a long way to go. I will check it again at lunch. I'll have to rake,skim and brush when I get home tonight.
    11-5 full sun
    Jun 2016
    344
    It's been raining all morning long, water level is up some.
    Checked FC at lunch, 9ppm, added more bleach to get me up to 11ppm. I know I'm supposed to be at 10ppm for my shock level but I just like to go a tad bit higher.
    Here's a picture my daughter took of how the pool looked (she didn't want to go out in the rain).
    11-5 full sun
    Jul 2012
    Tallahassee, FL
    34,010
    SWEET! You are trending towards blue now!!! Keep it up!
    Kim
  20. Back To Top    #20
    Jun 2016
    344
    Quote Originally Posted by kimkats View Post
    Kim
    I plan on it!!!
    11-5 full sun
