Thread: IntelliPH injector...
    Aug 2014
    Mesa AZ
    54
    Hi,
    I ordered a new 521510 acid injector valve for my IntelliPH recently and I got a part number that searching, is actually 522513Z though the box actually does say 521510. But I do see the 522513Z used interchangeably as the "acid injector check valve".
    My concern is there is no tubing, on the 521510 there's a short length of stiff black tube that reaches down to inject the water into the stream. The part I got does not have this, don't I need that?
    Here's what I got:
    Here's what I was expecting:
    Are these really interchangeable?
    30k plaster pool
    Pentair 011018 IntelliFlo, Pentair CCP520, IC40 SWG, IntelliPH Acid system
    Easytouch 4 + ScreenLogic2
    Apr 2015
    Waikoloa Hawaii
    13
    Re: IntelliPH injector...
    Old style/ new style. Compression fitting at the tops fit the same tubing for the acid injection. We have had some issues with the new style injector check valves sticking (resulting in the peristaltic pump tubes bursting....but otherwise the fittings work the same)
    Aug 2014
    Mesa AZ
    54
    OK, so it works fine even though there's no tube extending into the water stream?
    Thanks!
    30k plaster pool
    Apr 2015
    Waikoloa Hawaii
    13
    Venturi effect
