Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Remove copper from swg???
    ta2dwonderwoman's Avatar
    Jul 2016
    fall river ks
    502
    I just saw on another thread someone being told that they needed to remove the Copper from their Intex swg... do I need to tear this thing apart and remove the copper now?
    Windy ☆ 22ft round, 11,400 gal, intex ag vinyl, SF70110-1 Intex sand filter/2800 gph pump, CS8110 intex swg, city water, solar heater, TF100 test kit/speed stirrer, over the wall intex skimmer~fall river ks~SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    Re: Remove copper from swg???
    It would be a good idea. Copper is amongst the list of things you really don't want in your water. It stains the pool and can turn hair green.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2016
    fall river ks
    502
    Oh man...this thing is brand new...guess i better get started figuring out how to remove...
    Donldson's Avatar
    NW Ohio
    3,208
    As I said in the thread you are likely referencing, you at least want to disconnect the power to the copper rods. This will stop most of the copper from being introduced in to the water. It isn't a bad thing to completely remove them from the system though if you are feeling handy.
    Sent with Tapatalk on HTC Ten
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Jul 2016
    fall river ks
    502
    Well, i am handy to a point and what I can't do either due to health issues (heavy stuff for instance) or my girl brain (put oil in the dipstick hole the first time i put oil in a car many moons ago) , i call on my honey, superman!
    Jun 2016
    Central Oklahoma
    83
    The small side is the Cooper side. You should just be able to unplug. Am I correct?
    May/2018 AGP Coleman 24x52 vinyl, 13.6k gallons, Harris H1572228 Vortex 16 inch Above Ground Sand Filter System with 3/4 HP Pump, PoolBlaster Max, TF-100
    Run pump 24/7
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Quote Originally Posted by Tvarnell View Post
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Yes, at the very least unplug the copper bars.
    Being a Manufacturing Engineer I have access to lathes, and made a plug to put in place of the copper electrodes. I made it out of Delrin (polyoxymethylene).
    Here are the dimensions, incase someone is interested.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2016
    fall river ks
    502
    That was going to be my next question... I assume I need to cover or plug up that outlet on the generator so that water doesn't get down in it if it rains?
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Quote Originally Posted by ta2dwonderwoman View Post
    I made that plug so I can remove the copper electrodes from the unit.
    You can just unplug the copper electrodes, and leave them in there, this will be no different than having a heater with a copper heat exchanger. As long as you keep your pH in range you'll be fine.
    I covered my (unused) electrode plug with a heavy-duty storage bag, and cinched it tight with a nylon zip-tie. Then I cut off the excess from the open end of the bag so it will not collect water that could seep in past the zip tie. I don't have a pic, but it's covered similar to a lollipop.
    Dom - TFP Guide
    Jun 2015
    Stockholm, Sweden
    261
    Whoa, hold on! Intex stopped using copper in their SWGs several years ago, at least in the eco models. If yours is brand new, chances are it doesn't have copper. I'd make sure before messing with it. What is the model of your SWG?
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jul 2016
    fall river ks
    502
    Looks like it is a 28669EG... I am just getting to a point where I'm ready to start turning it on and I haven't how to chance to look it over... I know there are two plug-ins on the top of it directly on top of the tube where the water runs through. I will definitely have to check a Little Closer just see if there's actually a copper element or not
    domct203's Avatar
    Jun 2015
    CT
    3,890
    The copper bars at the bottom of the connector (red arrow) are very obvious:
    Dom - TFP Guide
    Jul 2016
    fall river ks
    502
    thanks! I will check that when I go out at lunch to check things out!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Quote Originally Posted by Mickelin View Post
    Yes, Intex did stop using copper in their SWGs a couple of years ago, but there is probably old inventory getting moved through. Worth checking but not a given anymore that it has copper electrodes.
    Jul 2016
    fall river ks
    502
    I got that model number off of my Amazon order but now that I'm looking at my owner's manual it has a different one so I'm going to go pull the actual model number off of the actual swg so that I know what's right...
    Jul 2016
    fall river ks
    502
    Looks like the model number is cs8110 and it does have copper in it.
    domct203's Avatar
    Jun 2015
    CT
    3,890
    That is the exact one I picked up this past weekend, yes it has the copper bars.
    [EDIT]I got the unit from a friend who bought it last year and never used it[/EDIT]
    Dom - TFP Guide
    Jul 2016
    fall river ks
    502
    Well it's super easy to remove them but then I have no way to seal that hole... I can just unplug it and cover it for the moment but I'd like to come up with a more permanent solution
    Jul 2013
    Long Island, NY
    554
    I bought that. I couldn't get the bars to budge at all. I just unplugged it.
    Someone that did get the bars out said they took the 2 thin metal pegs to a hardware store and just bought a washer to screw the bottom into place
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
  20. Back To Top    #20
    Jul 2016
    fall river ks
    502
    there certainly is a learning curve to this whole thing...but I think I am ready to unplug the copper thing and just seal it against water the best I can and move on with my process...
