If you look at any of my posts you'll note I'm a new pool owner in a new house. So I've been working on getting things moving, straightened out etc.
I have a couple of questions around the plumbing on my pool...
What are the 3 pipes coming up from the ground? I assume one is skimmer and one is drain - but what would the other be? I noticed they have broken off valves on them - how can I determine which pipe is which? Basically, I think the skimmer is not skimming enough and maybe I could adjust to pull more from skimmer vs main drain - but don't know which is which and what all the pipes are. Not touching until I figure out
Any other input etc is welcomed. Trying to get this thing all fixed up and running peak.
Also - is there any good spot to put a SWG in - don't know where I'd put it.
Thanks!
Thanks!
