Thread: Chlorine being used up but not showing CC
    Sep 2015
    Austin
    137
    I'm just SLAMming the pool.
    CYA tested at less than 30ppm (it was perfectly clear) and so I added about 14ppm bleach. After the first hour, there was a small reduction in FC and CC was .5.
    An hour later, FC was at 12ppm but no CC showing
    Added more bleach about 4ppm
    Now, 2 hours showing at 12ppm FC but no CC
    Huh?
    26,390 gallons IG, Centex plaster, Hayward DE 4820 filter, Century Centurion B2859 pool pump motor.
    Booster pump for polaris 280
    Spa
    Built 1997
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Re: Chlorine being used up but not showing CC
    It's very common. CC's are reduced by the sun and the FC. So you are doing fine there. I would defiantly say you need to get some CYA in there right away.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Sep 2015
    Austin
    137
    really?
    on the original thread where I queried this and whether the r0013 reagent had stopped working, I was advised to assume 30ppm. When I tested the water last, a few months ago, cya was at 55ppm. We have not had significant rainfall over this period.
    Spa
    Built 1997
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Oops. Didn't note the other thread. Please ignore that part.
