Thread: Pool Putty
    Feb 2016
    Los Angeles, CA
    37
    Pool Putty
    Does anyone have experience with pool putty epoxy to fill cracks in the pool plaster? If so, how long can I expect this stuff to last?
    Thanks
    22,000 gallon in ground pool with pebble finish. Pentair DE filter with Pentair VS pump. Built in the 70s but completely redone (including new pebble finish, equipment, and plumbing) in August 2015. K-2006.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Pool Putty
    My PB used pool putty to fix a crack in pebblesheen that leaked water in 2012 and it is still fine. He fixed two more cracks later that didn't leak, also fine.
