Thread: Pentair Racer is dying, considering Polaris 280, what do you think?
    Austx's Avatar
    Jul 2015
    Austin TX
    15
    The Racer cleaned wonderfully, until everything that could break on it pretty much did toward the end of the first year. Clearly not going that rout again. Our pool, including 1.1 hp booster pump is only one year old so my thought is to stick with a boosted pressure side cleaner. I've read robots are the future, but with our sunk costs for the booster, and the additional expense for a robot and the fact that my wife does not like the idea of cords around the pool, I'm leaning away from them this time at least. My first question is, what kind of challenge is ahead of me with switching out wall fixtures if I switch to a Polaris 280? Would it be just as simple as unplugging the Racer fixture and plugging in the Polaris fixture? I've read that Polaris makes specialized boosters for their cleaners. Is there any reason to be concerned that the 1.1 hp booster I'm using would not work well with the Polaris 280? Any recommendations for other similar pressure side cleaners? Reliability is mainly what I'm looking for at this point. I'm happy to replace parts every two or three years, as long as I can count on what ever I end up with working reliably.
    Just finished 2/19/16
    16,700 gal. free form, IG, Pebble Sheen, Pentair Quad D.E. 100, Pentair IntelliFlo Variable Speed, TF-100 test kit with speed stir, pressure side Pentair Kreepy Krauly Racer with booster pump, Paramount Ultra UV, Pentair Rainbow #320 Chlorine/Bromine Feeder, sheer descent waterfall, bubbler
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Pentair Racer is dying, considering Polaris 280, what do you think?
    Man I hate to hear that, I love my Robot so much. Sorry I dont know, but there are others here with those cleaners that can likely help.
    Essential Links:
    el duderino's Avatar
    Jun 2008
    Austin, TX
    118
    I have a Polaris 280 BlackMax that is nearing retirement. They require a pretty hefty investment each year to keep running, and with the black parts costing 30%+ more than white, mine has become quite the Frankenstein, not to mention he is Gray now as he's faded. I'm looking at a lot of money for repairs right now, so most likely going Robot. I considered the Racer, but the reviews and lack of available parts scared me into more research. Nice looking cleaner though for sure! If you're set on sticking with a pressure side cleaner, I think the 280 is the way to go.
    Our pool- (Completed March 2009)
    20k gallons, 38x15 Free Form Gunite (3.5'-8'), 26' Negative Edge and 7' Negative Edge spa with blower, Midnight Blue Diamondbrite, AquaLogic PS-8 control, Goldline Salt Chlorine Generator, 2x1.5hp Pentair 2 speed pumps, Pentair DE Filter, Pentair 400k BTU Heater, and BlackMaxPolaris 280 w/ Hayward booster pump, Pentair Prowler 920, DIY Stenner Chlorinator
    espejo's Avatar
    Nov 2014
    Kingwood Texas
    152
    I talked to the Pentair rep on Tuesday because the left fron wheel broke off due to a break on the chasis plate and they said there is a 3 year warranty on the Racer. The materials say 2 years but the representative confirmed it was 3 years. Anyway, I would call them and they will send replacement parts to fix the cleaner. They may even warranty the cleaner and replace it. I called my pool builder and they replaced the entire unit. They said they had to redesign it due to premature breaking of parts. The pool rep who replaced the unit said the redesigned unit is very good. Anyway worth a short. There's a thread here about the Racer.
    40x15 IG, 19,000 gallons, Taylor K-2006C, Intellichlor IC40, Pentiar 1.5 hp Intelliflo VS, Pentair 420 Clean/Clear Filter, Speedstir, Stonescape - french grey, Travertine Paver decking, Completed August 1, 2015.
    Austx's Avatar
    Jul 2015
    Austin TX
    15
    That is exactly what happened to mine. After hearing your experience I called my pool builder and they are coming out on Monday to fix/replace it. You just saved me $500. Thank you!
    Aug 2016
    Round Rock, TX
    94
    That's why I love these forums. Group hug!
    Chris & Lea Stoddard
    20k gal, IG shotcrete/pebble pool/spa combo
    Filled 11/19/2016
    All Jandy: DEV 60, PS Stealth 2 hp 2 spd, LXi (gas) heater, PDA-PS8
    Stenner 45MPHP22 for chlorination
