Results 1 to 7 of 7
Thread: Question on replacing air relief valve for my filter
    Hi guys, I am trying to fix the air leak that are on top of my filter. After some investigation, I noticed that air is leaking out of my pressure gauge as soon as the pump is turned off. But with my filter being an really old model, I have not been able to find the suitable replacement for my air relief valve. Therefore, I am wondering if any of you ever had an air relief valve like this and what you used to replace it.
    Any suggestion/advice is welcomed. Thanks so much!
    30,964
    Re: Question on replacing air relief valve for my filter
    Unscrew that base pipe that is screwed into your filter body and take it to Home depot or, better yet, a pool store and get the whole assembly replaced. Lot's of ways to get a new one.....that one looks home made.
    Or you can simply unscrew the gauge and replace it.
    Jul 2012
    Dallas, TX
    179
    cp48107
    I have a similar Tank to yours, an older Nautilus Tank, and had previously been using the same type of Bleed Valve.
    I had problems with the original Bleed Valve not completely closing, allowing some water to drip from the valve outlet.
    I installed a Mini Ball Valve & some 3/8" OD Vinyl Tubing to replace the original Bleed Valve. Here's a couple of links from the online Lowe's store:
    Shop Kobalt NPT Mini Ball Valve 1/4-in at Lowes.com
    Shop EASTMAN 3/8-in x 20-ft PVC Clear Vinyl Tubing at Lowes.com
    I bought a Parker 169P-6-4 Male Elbow fitting (see picture) to install the parts. I wanted to use some tubing to route the air/water bleed output into a bucket away from my house wall when I have more air/water to bleed from the Filter Tank in the event of more involved maintenance procedures.
    If you want to replace your valve with the same kind, they're available on the 'net at Amazon & other locations. Here's a Home Depot link:
    http://www.homedepot.com/p/Powermate...yABEgLJh_D_BwE
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    Thanks so much Scoop, this is exactly what I am looking for.
    Jul 2012
    Dallas, TX
    179
    Quote Originally Posted by cp48107 View Post
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    good job Scoop!
    Jul 2012
    Dallas, TX
    179
    Quote Originally Posted by woodyp View Post
    good job Scoop!
    I owe this forum. I'm reminded of that every time I look outside & see my pool's water shimmering with crystal clear clarity for the last 3 years.
