Results 1 to 10 of 10
Thread: Concrete scupper wok bowl-how to terminate pipe within bowl
    Jul 2016
    Austin, TX
    353
    I have a couple scupper bowls similar to the attached photo. These will have a 1" PVC pipe coming up from the bottom. I realize you don't want to have a 1" pipe sticking straight through the bowl to fill or you'll likely end up with a fountain. Should this terminate with a 90degree elbow, a tee, etc?
    Build thread - 15'x30' rectangular gunite pool; 17,400 gal; 5'x8' spa raised 12" w/ 8' spillover; 10'x6' Baja shelf; Two 18" tall columns w/ 27" water bowls; Light travertine coping w/ Light 2x4' split travertine ledgestone; Jules Rustic Blue tile; Pentair IC60 SWG; Pentair IntelliFlo 2 VST; Pentair SuperFlo 1HP; Pentair CC520 Cartridge filter; Pentair Easy Touch 8 w/ ScreenLogic2; Four Pentair GloBrite; Raypak 406 heater.
    mas985's Avatar
    Pleasanton, CA
    11,986
    Re: Concrete scupper wok bowl-how to terminate pipe within bowl
    Just cut the pipe flush with the bottom of the bowl. As long as you can control the flow rate with a valve there should not be a problem.
    Mark
    Jan 2012
    'burbs of Augusta, Georgia
    8,577
    You can also add decorative river rock in the bowl if you want to hide the pipe. Black river rock would look nice.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Dec 2016
    Austin, TX
    115
    Foosman,
    I have two scupper bowls planned for my pool. Each one will have a lighted bubbler it. If I did not have the lighted bubbler, I would consider one of these flush return eye balls.
    http://www.poolfittings.com/flush-mount-return-fittings
    You could leave the eye ball out if you just want free flow, or make it a bubbler if you have a big enough bowl. I think they cost $8 each. I plan to put some hydraulic cement with a grout layer and pebbles to fill up to my bubbler nozzles.
    Incidentally, where are you getting your bowls from? I have been tempted to cast my own bowls because shipping is ridiculous and I want big bowls.
    You definitely need a trim valve per scupper.
    Jul 2016
    Austin, TX
    353
    Quote Originally Posted by Ramdough View Post
    Foosman,
    Yeah, shipping was more than the bowls. I had then shipped from Phoenix Precast Products, Inc. A pair of 27" bowls cost $218, crate and shipping $314. I'll ask the boss if she wants bubblers or free flow. I was thinking of sealing the pipe to bowl opening with A+B epoxy. I like the idea of river rocks if we do a free flow, but will need something besides a 1" pipe opening to keep the rocks out.
    Dec 2016
    Austin, TX
    115
    Quote Originally Posted by Foosman View Post
    Sent from my iPad using Tapatalk
    If you install the eye ball socket, you could show the boss both options and then change it later if you change your mind.
    Mar 2015
    Las Vegas NV
    481
    They used a 180 degree connection on mine so the opening to the pipe points down towards the bottom of the pot. Works like a champ.
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Maytronics Dolphin Nautilus Cleaner
    Jul 2016
    Austin, TX
    353
    Quote Originally Posted by QingGuy View Post
    Sent from my LG-H811 using Tapatalk
    Thanks!
    Jan 2016
    Mesa, Az
    560
    You don't need anything fancy. Cut the pipe flush with the bowl bottom. Cut the end off a CMU block leaving one inch legs. Set the cut-off legs down to divert the flow and pile your rip rap on top to hide the CMU. if you have a VSP turn the water feature on AFTER it cycles down out of its prime speed or it will overflow your pot. Works like a charm . . .
    17' x 30' rectangle pool, two 7' x 7' baja decks, 6' x 8' raised spa. Hayward 2HP VSP for features, filter and returns. 2HP single speed for 9 spa jets. 1HP blower for spa bubbles. In-Floor cleaning, Cartridge filter, AquaConnect automation, 400K BTU NG heater. Plaster is Stonescapes mini-pebble in Aqua Blue + abalone shell TF-100 Text from Neighbor -- They're digging your pool!
    Dec 2016
    Austin, TX
    115
    Quote Originally Posted by BigEinAZ View Post
    I think that if you did not want the bubbler, this would look really nice. Maybe use some black river rock to make it pop.
