Thread: The Black Plague
    Jul 2015
    High Point/NC
    2
    The Black Plague
    I'm new to the forum and a relatively new pool owner. We bought our house in early 2015 with a pool/swamp containing several dead chipmunks and a bull frog bigger then my head. The plaster was flaking off in some areas and hadn't been kept up in about 1.5 to 2 years. We had it chipped out and replastered and replaced all of the floor returns/drains as the PVC was dry and crunchy. After several months of running a 3 hp non programable fixed speed pump, we replaced it with the intelliflo vs (huge energy savings).
    As new pool owners, we asked the pool replaster guy how to take care of the pool. He pretty much said to drop a chlorine tablet in each skimmer and replace once it was just about dissolved, buy a test kit and go from there. The chlorine level was always a bit low on tests, but it always looked great, last summer we noticed a few black spots on the bottom and apparently they multiplied over the winter.
    I've done some reading here and it looks like the best course of action might be the SLAM method with lots of scrubbing with a stainless brush during the process.
    Here are the pool test readings as of this afternoon:
    FC 0 (was 4 the night before)
    ph 7.2 (added 1 gallon muriatic last night)
    TA 40 (added 24 lbs baking soda today)
    CH 300 (added 7 lbs calcium chloride today)
    CYA 40
    My test kit is a Taylor I believe, blue plastic box and I've been using Clorox brand Chlorine tablets which I believe have Trichlor.
    2 Questions:
    -People say to stock up on bleach before a SLAM, does that mean 20 gallons, 50 or more?
    -I have a gas pressure washer, could I use this to remove the black spots while the pool is still full?
    Thanks for any advice,
    Dave
    CITY: High Point, NC POOL: 22x40, approx. 35000 ga, Inground, Plaster (replastered mid 2015), Pentair Intelliflo VS 3 HP Pump, Large Triton Sand Filter, 2 Wall Skimmers, 2 Wall Jets, 1 Floor Drain, 9 Floor Returns, Guessing 1968 Original Build.
    Jan 2012
    'burbs of Augusta, Georgia
    8,585
    Re: The Black Plague
    Hiya Superdave.... I need to know which test kit that Taylor box is? It sort of is important to know for your FC.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    What are you targeting for your TA? Seems too high. Pool School - Recommended Levels
    No, blasting the algae won't help, it will reattach and grow again, it needs to be killed. More about black algae here, Pool School - Black Algae
    May 2011
    lebanon tn
    370
    Quote Originally Posted by pooldv View Post
    Welcome to TFP!
    Just to clarify, the pressure washer might replace the brushing but you still need to slam to kill the algae.
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Jul 2015
    High Point/NC
    2
    It's actually a Leslie's Pool Supply knock off. It's a DPD test kit, I believe the cal measurement only goes to 10.
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,667
    Taylor Technologies 81329 Chlorine FAS-DPD Service Test Kit <--- is it this one?
    or one of these:
    Taylor Technologies K-2005 DPD Complete Chlorine Kit
    Taylor Technologies K-2005-C Service Complete DPD Test Kit
    Taylor Technologies 18571 DPD Basic Test Kit
    Unless it is the top one, please consider ordering a standalone FAS-DPD test kit like this one for $30
    http://tftestkits.net/FAS-DPD-Chlorine-CC-s-test-p47.html
    Some pool stores sell the components of that kit, but often ends up being more expensive and not as fresh. One way or another, the "FAS-DPD" is what we're looking for, not just "DPD"
    "drop a chlorine tablet in each skimmer" don't do that anymore, leave what's in there in there, but don't add for now please, they raise CYA too, see pool school
    maybe 8-14 gallons depending on how much of an inconvenience it would be to go back to store....definitely don't buy more than 20 for now, try to store in shade
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
