Thread: No drain acid wash 1st time
    righterjc's Avatar
    Mar 2017
    Orange,CA
    4
    HI I decided to do a no drain due to major scaling. We put in the pool 3 years ago and I do the maintance. Still learing and found this site. Pool 13000 gallon salt pentair system.
    At the moment I cant fine my before readings. After reading prior info on the site I dived right in . I turned off the system and added 6 gal's of acid. scrubbed and scrubbed. after 4 days I up'ed the ph level by adding 10 lbs of soda ash in stages, no change, added 4 boxes of borax in stages, not much in change, added 3 more boxes in stages and ph came to 7.2, Restarted the system and after 8 hours system reads as follows:
    fac 3
    tac 3
    salt 2600
    ch 500
    cya 50
    ta 150
    ph 7.6
    pho 1==
    copper 0
    iron 0
    Any thoughts so far
    I was going to add 28 ounces of acid to bring down TA. Figured its not a race and do it in stages to understand better. Thanks
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,875
    Re: No drain acid wash 1st time
    Welcome!
    How does the surface look? Did it improve?
    You look like you are on the right track to getting the pool back in balance.
    -Brian-
    Pool/Spa, Pentair Equipment
    righterjc's Avatar
    Mar 2017
    Orange,CA
    4
    Yes, Pool looks great. Surface is clear. Just need to fine tune it. Lower the TA and drain some water to help the CYA. Giving it a few days to settle. Was told I should put in 3 quarts of conditioner. Not sure if that is correct.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Can you please clarify what you mean by conditioner? If it is (guessing) a floc/coagulant/clarifier product no, but please hold off until we know for sure what you mean. Likely, we will advise against it, but I don't want to guess or assume further.
    Essential Links:
    Feb 2015
    Chandler AZ
    1,061
    Welcome!
    How are you testing your water?
    How are you chlorinating?
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    righterjc's Avatar
    Mar 2017
    Orange,CA
    4
    I went to Leslies for a better testing. They said I need to add instant pool water conditioner, approx 64 ounces they said to add. I do have the 5 way test kit. Since Im new I figured it would be better to have a pool store confirm. Still learning all the testing. Thanks for the help. I know I need to swap out some water and I was waiting for this weekend to do. For Chlorinating I assume my salt gen is doing it. But when needed I add Chlor Brite Granular Chlorine.
    update went and updated my testing with a cert pool man. readings as follows
    fac 7.5
    tac 7.5
    salt 3000
    cya 60
    ta 110
    ph 7.6
    pho 200
    I Was told to add 1lb 1oz of Leslie' s Chlorine Neutralizer to bring the FAC level down. Any thoughts
