Results 1 to 9 of 9
Thread: Spa draining into pool, ideas?
    Oct 2013
    Phoenix, AZ
    25
    Hey,
    I have a pool/spa that I'm having a few issues with. The spa empties about 3/4 the water during day back into the pool. I replaced two spring check values for the bottom and therapy jets, but that made no difference.
    Not sure what else could be causing this?
    I've attached photos of my system for reference.
    Photos: https://www.dropbox.com/sh/8otl2lab4bimor1/AADThr5ubcQUM7oJHv3piUWja?dl=0
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: Spa draining into pool, ideas?
    I've had this "problem", off and on for years. When the filter shuts off the spa drains into the pool with spa level going down to the jets. Doesn't really bother me but if there's a fix I'd be interested.
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    Oct 2013
    Phoenix, AZ
    25
    No one with suggestions?
    Size of pool (gallons) = 15,000
    Pool Type: is IG (in ground)
    Construction: Plaster
    Filter type: DE
    Filter Manufacturer: SM/SMBW 2000 Series
    the size, model number or flow rate of the filter.
    Pump in HP = 2
    Pump is two speed
    Date of pool build/install = circa 2001
    with spa
    Jun 2016
    Martinez, CA
    241
    Elevated spa? In line chlorine puck feeder? More info is needed (possibly some piping pic would help) to give a recco. Normally if a raised spa, a checkvalve leak is most likely. Some chlorine feeders plumb into the pool return lines will do this too ( ask me how I know��). Since you replaced the checks, take them apart and ensure no glue dripped into the rubber seat area and verify the checks dont have a drilled hole in the flapper (like is done for some solar install checks and diverter valves)
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    Jun 2016
    Austin, TX
    335
    Is that how you usually have the valves set in the pic? Try turning the spa return back on...are the pool returns off too in that pic?
    13k Gallon IG Pebble w/ attached Spa, AquaRite T-Cell-15 SWG, Hayward DE6020 Filter, Hayward 2 HP Pump, Hayward 400k Heater, TF-100 Kit, Pool Logger
    Oct 2013
    Phoenix, AZ
    25
    Quote Originally Posted by RussellC View Post
    Yes that is usually how I have them set for cleaning. With spa return on, it would lower pressure of pop up cleaners and cause non stop spill over from spa to pool.
    Filter type: DE
    Pump in HP = 2
    Pump is two speed
    with spa
    Oct 2013
    Phoenix, AZ
    25
    Quote Originally Posted by Rossterman View Post
    Hi, see the link for bunch of pipe photos. I'll double check the replacements I used as suggested. No in line Florine feeder.
    Filter type: DE
    Pump in HP = 2
    Pump is two speed
    with spa
    Jun 2016
    Austin, TX
    335
    It drains when the pump is running? not when it is off? And you have the spa suction and return closed? If that is the case, looking at your picture, the only thing I can think is the check the suction side valve diverter for leaks.
    Oct 2013
    Phoenix, AZ
    25
    When the pump is off it drains
    Filter type: DE
    Pump in HP = 2
    Pump is two speed
    with spa
