Hey all, been on here for a while. Pool finished a few months ago and here is where I'm struggling.
Im struggling to know where to set some setting with the VS pool and the cartridge filter.
I think I'm good with the standard Turnover needed per day. Done the math and I think I'm good understanding I can run the VS at 1000RPM for set period of time to get the turnover needed.
Let start here.....
so many variables.... Thanks in advance!
Let start here.....
- For Turnover, where do you set the Jandy Valve, does it matter? Main Drain Vs Skimmer or how much to either side.
- For Floor Cleaning, while the PV3 in floor cleaner (with independent booster) is on, What speed do you run the VS filter pump? Max so that its sucking in as much as possible while cleaning?
- And while floor cleaning where do you set the Jandy Valve, does it matter? Main Drain Vs Skimmer. I assume mostly so that the skimmer is almost off. All the way off can cause pump strain at high RPMs, Right?
- And with a VS filter pump... how do you measure the pressure to know when you need to clean the filter? at full RPM? with Jandy Main vs Skimmer... and to add another variable.. where do you put the Pool return vs water feature valve to measure....
