Thread: Hotspring Envoy Vs Caldera Geneva + Other questions
    Mar 2017
    England
    1
    Hi all,
    I've been looking into the possibility of having a hot tub for the past few weeks and have wet tested lots of cheaper models and some more expensive and it really came down to 2 models from rival yet same company brands.
    The Hot Spring Envoy and Caldera Geneva.
    They both had great power and had some amazing features that rivalled each other.
    We (me and my mrs) loved the motomassage on the Envoy, but felt the leg jets in the Geneva were a welcomed bonus.
    We also loved the wireless control in the Envoy and wondered why Caldera (also part of Watkins/MASCO) hadn't implemented anything similar.
    The question is, which one would you go for?
    The other vital question comes down to water softness. I know that the Envoy has the ACE water system and I already have a water softener fitted to my main water supply. Upon checking with a tester, of which states for ACE it should be between 25-75 and their website stating 50ppm, mine was somewhere around 10-15. Would I need to top up with hard water or do something else to balance things out or would it be the softer the better?
    On a similar note - How would the Caldera (no ACE system) be with my water supply? I wouldn't want to destroy any of the components due to my water.
    Andy
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Hotspring Envoy Vs Caldera Geneva + Other questions
    Welcome to the Forum Andy!
    I don't know anything about these units, but hopefully a bump will get them seen by someone who does.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    We recommend a minimum CH level of 125 ppm in hot tubs. More here about raising CH, Pool School - Recommended Pool Chemicals Here is the process I use to maintain my hot tub. It has worked great for several years now. How do I use Chlorine in my Spa (or pool)?
