I'm going to be buying chemicals online and in bulk, so I'll need to find ways to measure them out when putting them in the pool. Been using this for a while for things like muriatic acid, liquid chlorine, and anything else for volume and it's worked well. For weight, I have no idea what to use. So I'd like to know a couple of things.
Thanks!
- What are you using for volume?
- Is what I'm using for volume ok for the chemicals we deal with?
- What are you using for weight?
- What would you recommend that will be fairly precise for low weight (0-20 lbs)?
Thanks!
