Hello
I have a two pump set up. One for my DE filter and one for my Spa Jets. When I run both pumps at the same time (normal spa operation) the water that comes out the jets is cooler than the spa water temperature. If I run only the main pump it is the same temperature as the spa water.
There must be some sort of leak but I don't know where to begin. Im sure you will need more info, I'm happy to give it just tell me what information you need.
Thank You,
Chase F.
Thank You,
Chase F.
