Thread: Sealant paste application
    Jul 2014
    Greenville, SC
    57
    Stupid novice question: Do pvc connector threads need to be dry before applying a sealant paste? I have a leak above the Polaris pump. Even though I've turned the Jandy valve off, water is still trickling out at this connection when we unscrewed it.
    I'm thinking of using Rectorseal 5 or T2. Is one of these preferable over the other?
    TIA
    2008, 22,700g, vinyl, IG, SWG, Taylor K-2006 FAS-DPD.
    (More info to come when I figure it all out).
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Sealant paste application
    No, not particularly, a teflon based pipe dope will seal if there is some water present. Is this a union? Is there an o-ring? If there is an o-ring th pen no thread sealant is needed. A silicone o-ring grease should be used on the o-ring.
    Jul 2014
    Greenville, SC
    57
    Thanks. I don't think there is an o ring. There was old teflon tape on the threads.
    So do you think a small but steady trickle of water will be ok?
    DFW, TX
    24,974
    Yes, that should seal up fine. You can use pipe dope or teflon tape.
    Jul 2014
    Greenville, SC
    57
    Thanks!
