Results 1 to 8 of 8
Thread: Noisy motor
    Jan 2017
    Atlanta GA
    6
    Noisy motor
    Started up pool here in ATL. Motor very noisy after the winter break. Been running a week, no change. New to the pool and told it was replaced 3 yrs ago. Repair / replace? If replace, what are the best options for a 1HP. It is fairly close to the neighbors, so need something quiet.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Noisy motor
    Welcome to the forums. If you're mechanically inclined, you may change out the bearnings. Check youtube, pool motor bearing replacement. It's an easy job overall. If you want to swap out the motor, go with a 2-speed. Running on low speed you'll save money.
    Do you have water features? You don't have to change out the whole pump, just the motor.
    sammm's Avatar
    North Richland Hills, TX
    257
    Re: Noisy motor
    A capacitor on the way out will make a lot of noise too.
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    Apr 2013
    Sacramento, CA
    2,769
    Re: Noisy motor
    Not sure I understand how a dying capacitor will make noise.
    Anyway, I would go with a new 2 speed motor. It will save you mucho cash.
    sammm's Avatar
    257
    Re: Noisy motor
    I don't understand either, but mine did that yesterday.
    Jan 2017
    Atlanta GA
    6
    Re: Noisy motor
    No water features, and yes, I capable of a bearing swap. But thinking to just do the motor swap to a 2 speed....How do they work/set up? Just a swap out?
    Apr 2011
    Murrieta, CA
    2,360
    Re: Noisy motor
    Pretty much. You'll need a new shaft seal, maybe a seal kit, and a switch to switch from low to high.
    Jan 2017
    Atlanta GA
    6
    Re: Noisy motor
    Thanks. I have an Aqua Logic AQL PS8 system controller. Looks like it has 2 speed control built in. So what would be the runtime profile in low speed? How to figure out the schedule?
    Ps. Any brand recommendations for good quality?
