Thread: Vinyl liner getting frequent holes where sun concentrates
    itsme_lp23's Avatar
    Mar 2017
    Suwanee GA
    4
    I have a vinyl Kafko liner that was installed in 2011. Since we have owned the house in July 2014, I have had to patch dozens of dime to half dollar sized holes where the sun reflects off windows onto the pool liner. Has anyone else had this problem? I was told by my pool guy that it could be the black granite color in combination with the thickness of the liner (which I cannot find in the paperwork that was left). I don't know if this Kafko brand is a reputable liner or if there are better options. We lose quite a bit of water when the temps are up and we will have to replace this liner. Any recommendations for a liner brand and thickness for those of you that have pools in hot climates that get direct sun much of the morning through early afternoon?
    What are options for filling the pool after a liner replacement? Our hose is tied to our main water and we get charged for sanitation which makes filling our pool ridiculous. Are there alternatives that I should consider?
    thanks in advance!
    Jan 2013
    Long Island, NY
    184
    Re: Vinyl liner getting frequent holes where sun concentrates
    Have not heard of window reflections ruining a pool liner, but I have seen first hand signs of window reflections ruining vinyl siding of an adjacent house. The reflective coatings they put on glass can be the culprit.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    itsme_lp23's Avatar
    Mar 2017
    Suwanee GA
    4
    Yes I have read quite a bit about the siding damage. I am really looking for anyone with experience with this and what thickness liner and brand is recommended to combat it. I will also take general liner product recommendations.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,995
    I've never heard of this either. But.....on the water concern, many local municipalities will give you a break on cost for filling a pool if you contact them.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Nov 2011
    Moberly,MO
    1,025
    UV rays are hard on vinyl. We are starting to see more and more where pools that aren't protected from the sun that it deteriorates more often from exposure.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,901
    If your (or your neighbors) windows are concentrating the reflected light on a specific point in the pool then no matter what liner you get, it will fail. Vinyl siding is much thicker than any liner. Before taking care of the liner, you need to figure out which window is the culprit and fix it first. I have seen people say ti's the coatings and others say it's a defect in the glass that makes it slightly convex (thus concentrating the reflection).
    Support the site
