Awwww, don't delete it. You can't have too many shots of a beautiful pool! I love that change from hard cold gunite to fresh, smooth plaster. I think 'serene' when I see it.
Congratulations! Now, good luck trying to wait for the acid wash and fill!!
So pretty!! Can't wait to see the water! Hopefully you'll get some sleep tonight??
Congrats Az, the finish is beautiful. I can't wait to see it tomorrow.
That's going to turn out fantastic. Won't be long and you'll be sitting in your pool, looking up at the stars, and trying to comprehend that this is YOUR POOL !! You'll know your water is good when you can stand on the edge and count dark pebbles in the deep end.
Here is our start up page. Make sure to run it by whoever holds your plaster warranty card:
Pool School - Start-up New Plaster
They are doing the middle one on yours- traditional start up. NOTE the 30 days no swimming does NOT apply to your start up!!!!
You can use a manual vacuum head on your pool. No wheeled ones yet.
Does this help?
Did I share my set of links for new pool owners with you way back in your pages? You know what? I am going to go ahead and share them now just in case I did not before:
Print these out:
Bookmark these:
http://www.troublefreepool.com/calc.html
Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
Kim
The liquidgoldCYA is fine but it is quite a bit more $$. You do not need to pour in the skimmer though. Turn your pump on high and pour in front of a return.
Your PB may add it for you. Ask to be there and write down what they add to your water so we can see what is what.
They might put some kind of sequester or "start up" liquid in the water. That is normal.
Be aware you water and plaster may look a little green in the beginning. This is VERY normal so don't panic. It will even out as the water gets balanced.
If you show your test kit and that you know how to use it to the PB he might allow you to do your own testing. We have seen that many time here at TFP. Most PB are not used to someone that knows what they are doing so..............
Kim
Water??? Water???
Really good startup guide and video:
http://www.wetedgetechnologies.com/files/2014_Start_Up_Form.pdf
28 Day Pool Start Up - YouTube
Out of the gate you will likely need muratic acid and perhaps soda ash. I ended up starting with 3 gallons to get my TA down from 180 to 80 and am up to adding 4 gallons total after 1 week. You want to do a traditional start up. You can always "boil the pool" later...aka "acid start up" if you don't like the uniformity. For determining how much acid, I used this quick guide:
https://www.hayward-pool.com/pdf/manuals/Salt&SwimChemistryGuide.pdf
