Page 1 of 21 123411 ... LastLast
Results 1 to 20 of 412
Thread: New owner-builder (kinda) in Arizona
    Azsunsets's Avatar
    Mar 2017
    San Tan Valley, AZ
    416
    I've decided to go with a company that does the pool design/engineering, & gives you a sub list, as well as helps with questions along the way.
    I'm a little nervous & have a lot to learn!
    All I have so far is the first shot at my design - a little tweaking to be done.
    I welcome any comments/suggestions regarding the design/process/equipment/decking, etc.
    Thank you!!
    Under Construction In-ground Freeform 11K gal Pentair intelliflo Clean&Clear cartridge filter, EasyTouch w/IC40, Baja Mini Pebble interior - Sky Blue, TF-100
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,493
    Re: New owner-builder (kinda) in Arizona
    Welcome to TFP! That's a very inviting design
    You've come to the right place to get effective pool design and building advice! I like the idea of two skimmers and choosing plants carefully to reduce leaves and other debris falling in the pool
    That pool is going to be an amazing addition for your home.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,883
    That is a pretty design. When do you think you will start?
    For the filter go as big as you can. The bigger is it the longer you can go between cleaning it. Will you do SWG? Again the bigger the better!
    Kim
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Welcome to TFP!! It's a great place full of wonderful giving people and an unending wealth of knowledge and help!
    What a pretty design! Make sure you have good water movement off the shelf so it's not a collecting place for debris, also make sure you have a light installed there so you don't have a dark zone in your pool.
    I like being able able to control my pool from my phone, tablet or computer, so I recommend automation for it, in addition to the other advice you have already gotten from Kim and Jet. Also, a robot for cleaning the pool is the way to go! No need for an extra pump to maintain (and pay for!) just for a cleaner.
    Check out this thread for ad for more info on a robot many of us have bought and LOVE First Robotic Cleaner, Doheny's Discovery
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Azsunsets's Avatar
    Mar 2017
    San Tan Valley, AZ
    416
    Quote Originally Posted by kimkats View Post
    Kim
    I'm hoping to start in 1-2 weeks, depending on how long it takes to get the final design/engineering & permit taken care of.
    I'm not sure about doing the SWG, I think I will see how things go without it. I have a pool that I maintain at another house, & chlorine seems to work ok there.
    Thank you for the ideas!
    Azsunsets's Avatar
    Mar 2017
    San Tan Valley, AZ
    416
    Quote Originally Posted by Nursenini View Post
    I read some of the thread about the robots. I have been using a suction side vacuum (is that the correct terminology?) in a different pool, & it has done a great job. What benefit is there to using the robot instead?
    I was considering doing an in-floor cleaning system on this pool...
    Maybe I should ask for opinions on those in a separate post?
    Thank you for your suggestions!
    Azsunsets's Avatar
    Mar 2017
    San Tan Valley, AZ
    416
    Quote Originally Posted by needsajet View Post
    I'm not sure what they have planned for skimmers... what is the advantage to having two? The other pool I have, has one, so I'm not familiar with having an additional one.
    Thank you!
    triptyx's Avatar
    Apr 2016
    1,475
    IMO, save the money on the in-floor - they seem to be a bit of a hassle and can be expensive to maintain, but there are others here that are big fans of them.
    Two skimmers is nice because you can handle two different primary wind directions. If you place one on the end of the pool to which the wind blows most of the time, you can place another on the other end to get the debris on days where you get a contrary wind.
    Robots versus suction side cleaners - I personally love my Kreepy, but then I'm a little old school on this one. One advantage of some robots is coverage - some can be programmed and even manually controlled from an app to make sure you get all of the pool.
    As for an SWG, if you're going to skip it but may do it later, make sure your equipment pad's pipes are set up with enough space for one if you decide to do it down the road. My pad is very compact and I'm not quite sure how I'd manage to plumb an SWG into it - and I really want one.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Azsunsets's Avatar
    Mar 2017
    San Tan Valley, AZ
    416
    Quote Originally Posted by triptyx View Post
    Hmm, more to think about! Good point regarding leaving plenty of room to add SWG at a later date.
    Thank you!
    30,941
    For continuity, keep your questions in this thread.
    Nix the in-floor system. Not many people here on the forum have much good to say.
    2 skimmers is always better than one. I have never heard of people taking them out.....only wishing they had 'em installed or actually installing them.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,149
    As a note for limited space applications, cells can be installed vertically so this would allow for installation in even the tightest of equipment pads so long as vertical space is not also limited.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    needsajet's Avatar
    Jan 2016
    4,493
    Another advantage to a robotic cleaner is that it's doing most of the weekly brushing for you. I also vote for SWG and lucky you have Kim, Nini and others on your thread for bling advice They know the style stuff!!
    Oct 2016
    Phoenix
    203
    Suction-side cleaners have served me well for many years (Hayward Navigators) in my pools. It doesn't cost much to install a suction port now and then you can used it if you choose. As for skimmers, with my variable speed pump normally running at low RPM I don't think it would flow enough fop two skimmers to work well. It doesn't take much of a breeze to defeat the surface skimming function because my skimmer is on the west end of the pool and the prevailing wind blows away from the skimmer in the afternoon when I need it most. My wind blown debris usually sinks before it gets to the skimmer. If I could move my skimmer easily, I would put it on the other end of my pool.
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
    needsajet's Avatar
    Jan 2016
    4,493
    Yeh, that's part of my thought on two skimmers. By having two skimmers and a 3-way valve at the pad, you can select whichever skimmer works best. I need medium speed on my pump for quick skimming or skimming during windy weather.
    Jul 2012
    Tallahassee, FL
    33,883
    If you do get two skimmers make sure you are plumbed/valved so you can open/close each one separately. That will come in handy down the road.
    Kim
    Azsunsets's Avatar
    Mar 2017
    San Tan Valley, AZ
    416
    Quote Originally Posted by slickraft View Post
    I am planning having a suction port, for sure! I'm not sure about the wind direction here, but I will ask about the idea of 2 skimmers, as long as one pump would be sufficient.
    Azsunsets's Avatar
    Mar 2017
    San Tan Valley, AZ
    416
    So, you are saying you are only using one of the skimmers at any given time, correct?
    needsajet's Avatar
    Jan 2016
    4,493
    For two skimmers, there are separate pipes going from the pad to each skimmer. At the equipment pad, they each have their own valve, or can tee together into a 3-way valve.
    So you can have one skimmer at a time, half and half, or most likely with most of the flow (say 80%) coming from one skimmer that gets most of the leaves, and the rest coming from the other one. Lots of flexibility. And yep, just one pump.
    Azsunsets's Avatar
    Mar 2017
    San Tan Valley, AZ
    416
    Okay, thank you for the clarification! Not too many trees near me, but it might be helpful anyway.
  20. Back To Top    #20
    needsajet's Avatar
    Jan 2016
    4,493
    ...leaves, bugs and dust I wish I had two!
