Thread: Help! I have tried to repair this motor 3 times now. What is this noise?
    Mar 2017
    MA
    1
    Hello all,
    I have a hot tub that began to make a nose last season. After the summer shut down period I replaced the bearings in the motor and the spring loaded seal on the impeller housing. The motor has a loud noise that I can't figure out. See video link below. I tried to adjust the front bearing with a punch to keep it from spinning in the housing. Added a little grease to the rear bearing. I have disassembled and reassembled the motor a few times in attempt to figure it out. The noise use to come and go but now it's rather loud. It's not a hum and is not a capacitor because the motor is running. It is not a loud screech like a bad bearing. Just a drone noise.
    See video here:
    Hot tub noise - YouTube
    I appreciate any help or suggestions!
    It is a backyard spa with one 2 speed motor.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Help! I have tried to repair this motor 3 times now. What is this noise?
    It could be the shaft is out of balance or missing mounting insulation/loose mounting fittings.
    Mar 2017
    Arizona
    4
    Does it have a fan/cover on the end? Maybe the cover got tweaked and the fan is now hitting it.
