Thread: Black Olive Tree
    Feb 2017
    Miami
    1
    Black Olive Tree
    Hello, I am new to this forum and currently in the process of getting an inground pool with a salt system. I have a black olive tree that I was told should be removed because its leaves will stain the pool and I will be spending all my time cleaning rather than swimming. The trunk is about 6 to 8 feet from where one of the corners of the shallow end will be. The tree provides shade which we need in Miami. This tree does not bear fruit but it does drop leaves.
    Should this tree be removed? If so, any suggestions on replacement?
    Thank you
    JoyfulNoise's Avatar
    May 2015
    14,083
    Re: landscaping ... black olive tree
    See here - http://www.entnemdept.ufl.edu/pestal...lars_mites.pdf
    Unless you're really in love with the tree, having it anywhere near the pool sounds like a bad idea.
    On a personal note, I had a mesquite tree near my pool that offered some shade. It also created a lot of leaf debris & mess. It was gotten rid of last year and my pool care went from emptying a leaf canister and skimmer daily when it would drop stuff, to barely cleaning them out once per week. So trees do have huge impact on pool care.
    Matt
    triptyx's Avatar
    Apr 2016
    1,476
    I had to do the same thing - chainsawed that spiky mesquite that was partially overhanging my spa and pool. I miss the shade, but it was COMPLETELY worth it in not having my filter and skimmer (even with a hairnet) clogged up constantly.
    nma - I'd remove the tree if it was me. You can ask a local grower about having something else put in its place that is pool-friendly. There may be some good low-litter options for you!
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
