We're running our hot tub with sodium bromide and recently converted from a bromine generator to brominating tablets (floater). The first two heater elements (replaced about 2 weeks apart) were corroded very likely due to low calcium levels (11ppm). Once we brought the Ca level back to 125ppm, we've had regular water tests with good results. Now, we've had a 3rd heater element go?? What might be causing this (if not a chemical issue). We've been advised to empty our tub, refill it and wait for the dissolving brominating tablets to bring the bromine level to 3-5ppm -- I'm not convinced that will help!
