Thread: Variable Speed Pump - What Speed?
    Feb 2017
    Sierra Vista, AZ
    4
    Hi all!
    I grew up with a pool in FL as a kid, and I remember the pump had two settings - ON or OFF. My dad would have me turn it on when I came home from school, and off before bed.
    Fast forward 20 years:
    8 months ago, I bought a house with a pool! But this variable speed pump is confusing to me. I know I need to turn the pump on for a few hours each day, but I have no idea at what speed I should run it. How do I figure out how long and at what speed I should run this thing?
    Thanks in advance!
    14,000 gal IG w/ spa built 2005, pebbletec, Sta-Rite IntelliPro Variable Speed pump, Sta-Rite System 3 300sf cartridge filter, Sta-Rite 333 NG Heater, Zodiac G3 vac, A&A pop-up cleaners, waterfall rocks feature, Taylor K-2006 kit (ordered!)
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,310
    Re: Variable Speed Pump - What Speed?
    Red,
    Welcome to TFP.. A Great resource for all your pool questions...
    The whole point of having a variable speed pump is so that you can run it at whatever speed is dictated by the situation.
    I would run it at 1,000 RPM for normal circulation.
    I would run it at the lowest speed which makes your Zodiac work best.
    I would run it at the lowest speed that allows your pop-up cleaners work best.
    I would run it at the lowest speed that makes the waterfall look the best.
    Each situation may call for its own speed...
    Unless you have some sort of automation, you would program this speeds in the control panel on your pump itself. You do not normally turn the power off to a VS pump.
    Thanks for posting,
    Feb 2017
    Sierra Vista, AZ
    4
    Thanks Jim, that makes sense. Appreciate the tip!
    Followup - Is there a "safe maximum" speed? Can I damage the pump if I "run the motor hard" for too long?
    mas985's Avatar
    Pleasanton, CA
    11,987
    You can run at maximum speed for as long as you want although I don't know why you would want to. Nothing should be that sensitive to pressure and flow rate.
    However, since you have in-floors, I would run the pump long enough just for that. Circulation should be taken care of along with that. But why the second cleaner? Are the in-floors not working properly?
    Mark
    Feb 2017
    Sierra Vista, AZ
    4
    That's a good question. I have both because both came with the house. I'll probably take the Zodiac out and see how things work with just the in-floors.
