ouachita said:Mnb,
Absolutely beautiful.
I do have a question, what kind of cover was that that you used before the automatic cover? I have been trying to figure out a way to cover my pool while I work on the decking.
S1425405F said:Hi mnb,
Great pool and fabulous pictures. Can't wait for our vinyl pool to be ready. Love what you have done to the yard.
Haniff
Singapore
7' by 25' vinyl pool
pool1999 said:I know this in an older thread but your pictures are great! I am having an fiberglass pool installed soon and these pictures have put my mind at ease......
Thank you!
carlscan26 said:Why does the pressure side pipe on your pump split off? It lokd like one side goes to the pump and the other goes back down in front of the pad?
mnb said:carlscan26 said:Why does the pressure side pipe on your pump split off? It lokd like one side goes to the pump and the other goes back down in front of the pad?
Yes it does split. One side goes to the filter the other side goes to my slide.
carlscan26 said:mnb said:carlscan26 said:Why does the pressure side pipe on your pump split off? It lokd like one side goes to the pump and the other goes back down in front of the pad?
Interesting. Is that to maintain pressure for the slide? Is there a valve by the pool or at the pad to turn the slide on/off?
carlscan26 said:Yeah that's a nice feature with the poolside valve. What I meant to ask was why split off right after the pump and not filter that water?
