Since the end of summer, my TA has decreased from a range of 90-100 down to 70. My pH is slowing drifting up and is currently 7.9 I am reluctant to add acid in fear of driving the TA so low that I will get in to pH spikes. I suspect the problem may be that I have not added any tap water to my pool since late October (live in southern CA and continually pumping rain water out of my pool) I suspect that rainwater may be lower in alkalinity than tap water.
Should I add sodium bicarbonate to get the TA back up, and then add acid? Or should I wait until the rains are over hence requiring tap water to maintain pool level and see if that corrects the problem? Most recent chemistry from TF-100:
pH 7.9
TA 70
Chlorine 4.0
CYA appromimately 60
Would appreciate any feedback.
Les
pH 7.9
TA 70
Chlorine 4.0
Les
