So it is a skimmer and it is leaking and I need some ideas on how to best repair, but it's actually the return to the pool.
The Setup:
Admiral S20 skimmer with the flow reversed.
The return water to the pool is attached to the skimmer. When the pump is running it fills the skimmer with water and then it flows down creating what looks like a waterfall.
One of the ports is capped off and the other port is for water flow.
I have dug up the pipe all the way to the skimmer.
I haven't broken through the concrete encasing, however, the leak is not coming from any of the pipe joins. So it is leaking from where the pipe enters the skimmer, the skimmer itself, or the capped pipe.
I have capped off the ports from the top and filled the skimmer with water and the water level stays the same so it appears the skimmer body is fine, but it is leaking from one of the ports.
The ports on the skimmer are threaded. Here is a picture of a brand new one:
I have considered cutting the pipe and trying to unscrew the pipe from the skimmer bottom and thread in a new pipe. However, there appears that some sealant or something else was used on the threads and it seems to be hard so I am not sure if I will be able to unscrew it. Any idea what type of sealant may have been used and my chances of unscrewing it?
The other thing I have considered is using an epoxy putty. However, if I use an epoxy putty I am pretty sure once hardened I will have no chance of unscrewing the pipe from the skimmer?
I have also considered trying to move the pipe to the other port but it also appears to be threaded in with something that has hardened.
Any other suggestions or ideas?
Since the concrete is not giving me a full view of the bottom should i chip away the concrete from the bottom? If I do, then can i leave it once done or should I need to add concrete to the bottom?
The other thing I noticed is the glue from the joints leaking down appears to be gray in color and not blue. Does anyone know if pvc cement can be gray?
The Setup:
