So I started off strong with the TFP method... but really started to slack off, and went so far as to let my pool go over the winter without so much as the pump running. About 2 weeks ago I started it back up again. Ordered a refill kit for the TF-100, used a net to scrape what I could off the bottom (couldn't see), and added enough stabilizer to bring it up to 50ppm. Only, from past experience, I poorly assumed I was at 0ppm CYA, but in reality I was closer to 40ppm. When I had the refill kit I tested it and I was up at 90ppm... ugh.
For the last week and a half or so I said screw it and SLAM'd it with the outrageously high chlorine levels. My fill source is well water, and when we filled it originally it took a while to get the yellow tint (iron) out the water. I did not like the idea of draining 44% of the water to get it down to 50-60ppm. I assumed over time with friends and family using it I'd get the CYA back down with top offs, as in the past it's something I've had to periodically keep up on.
Anyway, the SLAM hit a wall about a week in. No noticeable improvement. After the first day or two of the SLAM, the filter color went from the dark algae green to brown. Almost like I was filtering out iron particles again. The filter would also hit the gotta-clean-it PSI within a few hours, even up until a few days ago. Despite the filter only looking 40% or so brown when I cleaned it.
The wall and the weird filter stuff caused me to suck it up and drain about 44% of the water. While it was down to that level I got in and scrubbed the walls, railings, and staircase. Everything had a light brown tinge to it. We get a LOT of oak and pine pollen during the off season when the pool sat for several months without circulation. Is it possible I'm dealing with pollen here? Would you do anything different other than re-start the SLAM when the water level is back to normal (it's filling up now.)
Thanks.
Thanks.
