Punch a Penny test
TC 1
FC 1
CC 0
PH 8
Acid demand 4
TA 150
Calc Hardness 295
CYA 40
Total dissolved solids 600
Just built the house with a 10000 gal screened in pool. At first all I was doing was using the red/yellow PH/Chlorine test kit. Oh kept climbing so I kept putting MA in, and then some PH down when that ran out. I was doing pretty well keeping it in range. Chlorine was super low and found the pucks in the coordinator dissolved . Put two more in and after a week or so I started seeing yellow on the chlorine side of the test. The entire time the pool was crystal clear. I was curious about a full read out so I had my wife run to the punch a penny for a test. We'll $100 later she comes home with a trunk full of chemicals. New chlorine pucks, liquid chlorine, MA, something called super metal control. I was skeptical but I put the acid and chlorine in only to shock the pool. That was on Wednesday. Here I am Friday night with off the charts chlorine (hasn't been super sunny in Tampa) and a super low PH. Should I be concerned? Or it will even back out with sun reducing chlorine and the diamond brute increasing PH. I also noticed a white, oily film substance in the corners when I was brushing today. Not sure what it was. My hand is super dry after putting the test kit in the pool as well. I'm pretty sure if I left it alone I would have been fine. Note: pool was filled from well water. Thanks!
TC 1
FC 1
CC 0
PH 8
Acid demand 4
TA 150
Calc Hardness 295
CYA 40
