Thanks, Kim! I wasn't brave enough to go with black coping but wanted something to break up all the grey We like the border,Love, love, love the border!!!! That makes it really stand out!
Kim
Sorry - I missed seeing this comment until now! Thank you! We're happy with it and I will post a couple more pictures with the border complete. I am keeping up with your renovation - it will be beautiful! And I love the tile you chose.LOVE the border!!!
MD here as well! I am off RT97 in western howard county. Our 23X43 pool was completed At the beginning of June this year. We had Leisure pools do ours. It turned out great but boy did we fight the county and the inspectors. The inspectors and our PB did battle a few times. I heard them on the phone one time going at it. Our pool should have been done over a month earlier. One hangup was the pool grounding. 99% of counties only require number 8 ground wire be wrapped around the pool. Howard county requires a large rebar grid or copper mesh ($$$$$$) around the pool and has to be at least 6" under grade. Well they laid the rebar grid across the tops of the skimmers which put the rebar like a 1/2" too high in those two locations. Builder said thats how he has been building them in howard county for over 30 years without issue but the inspector we had was being a prick. They had just completed a pool around the corner from us and did it the same way there and no problem but our inspector wanted to nit pick everything to pieces.
They even nit picked the $30,000 aluminum fence that frederick fence installed. Then frederick fence started to give ME a hard time when I told them they needed to come back and fix it to satisfy the inspector. I literally told them on the phone that I am hanging up and driving up to there shop and they better be ready when I get there and hung up the phone on the person. As I was getting in my truck the owner of frederick fence called me and said they would be out the next day to take care of the issues. At that point I was madder than I have ever been in my life and was ready to start kicking azz and taking names later (I am an easy going relaxed big dude but they had me fired up to the MAX). I am glad they called me back because i would have gotten in trouble that day.
Luckily we are on 3 acres and had a ton of room to do whatever we wanted.
Yeah very sloppy tile work. No attempt at all to align the tiles in the skimmer. I would ask them to redo it if they can. The bottom ledge should have been matched right to left. And that piece of coping is ugly too. No pride whatsoever in that job.
Also where those small tiles wrap around the step contour at least on the tighter turns I would have put cut/wedge tiles around the bends instead of leaving those large gaps. Functionally not a big issue just points to pride (or lack thereof) in workmanship. Also within the skimmers I would not have had the edges showing of the tiles in the skimmer. The tiles around it would have covered them. I have done tile work (for myself and others) and would never do a job like this.
On your skimmer issue, yours is similar to mine though they at first they appear different. Our skimmer is set at roughly the same height as yours (ours is a little higher), though they did angle up the tile entryway to marry up with the waterline tile. You can see the drop by the angle of the side tiles. They could have done that with yours though they didn't (that's just a look issue). Functionally, what it does is create a lower water level at which skimming stops occurring than would otherwise be the case. So when you have rains, you will reach your "full" point sooner, though you will still have room before the pool overflows.
We have an autocover which also played a role in ours but the end issue is the same. It's not a dealbreaker by any means, but does limit the effective range through which you can have your water level travel and still skim properly. Which means during periods of losing water (splashout or evaporation), you will need to fill your pool slightly more frequently than others. Again - not a big deal and more so an appearance issue.
However, resetting the skimmer higher is a decent size task and I would likely stay with the current arrangement. Others way disagree on the severity of the fix and the appearance. An appearance only alternative would be to have them tile it like ours, with the entry way slanted down, though this does nothing for the water level issue.
But I was pondering whether a 2 inch band of tiles underneath these might look decent. But a project for another time.
