I am new to pools, so please bear with me. I have kept my above ground spas working with various repairs over the years. I just bought a house and I like to understand how things work. I have the Pentair MiniMax Pro 400 gas heater that turns on fine and starts to heat - all lights on the panel are green, and then, after a short while, just the heater light goes out and it cycles in somewhat random timing but all within a minute of each other. It turns on then runs then shuts down...the service light does not come on. All other lights stay green.
The previous owner had recently installed a Pentair variable speed pump and runs it mostly in low speed (2,000rpm) for cleaning. They never heated to pool, just the spa. Could the flow detection be looking for a higher rate of flow? It seems I would see the PRESS light go out if that were the case.
Where is the best place to start? I am okay with multimeters. Hi Limit Switch? Some thermal regulator?
Looking for guidance please.
Mike
Mike
