- Jan 16, 2017
- 169
- Plaster
- Autopilot Digital PPC4 (RC-52)
Hey All,
I am new to the forum after lurking a couple of weeks. I am looking into putting an in ground pool in this year. I grew up with a large pool and have the sense that 800 sq ft is a good size (free form or rectangle...not sure yet). I am having trouble narrowing down on the pool builder as the national companies (Anthony & Sylvan for example) have some awful reviews despite a great sales rep. The local builder is not very responsive and despite claiming to build a much higher quality pool, they worry me that come build time they will be nowhere to be found. The owner is a bit older and may soon retire so I also worry about the warranty. I am hoping some might share insights on how to make a chose between the two. Price different is around 10%. Maybe I should keep looking? I talked to 5 builders, 3 in person. The main differences I see for the two I like most other than the above is as follows:
A&S
Arista Pools
A&S
- Dedicated lines, 3/8 rebar shallow end, 1/2 rebar deep end
- Jandy Plus 1.5 HP Pump
- Aqual Cal SQ-225 Heatpump 125K BTU
- Jandy Pro Series DE Filter 48 sq. ft.
- Jandy Fusion Soft - Nature 2 (yuck!)
- 2 Hayward Color Logic LEDs
- 80 sq ft Sunshelf
- Equipment installed on condenser pad like material
Arista Pools
- Dedicated lines, 1/2 rebar
- Intelli Pro Monumental Pump VS 3HP
- Sta-rite Pentair System 3 Filter (53sq ft)
- Autopilot Digital - Salt Purifiction System & Inline Mineral Chlorinator Combo
- Pentair Heat Pump 125,000 BTU UltraTemp
- Equipment installed on concrete pad
- 100 sq ft sunshelf
